Interior Caulk Failure - In New Construction - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 06:57 AM   #1
Exclamation
Moving into a brand new home this month, and facing big issues;
The trim work was caulked to the wall BEFORE the walls were primed,
Low quality caulk was used,
And it's cracking all over the place- windows, door trim, baseboards, etc..
We are renting the home from a family member with the understanding that it will be willed to us, so we can't exactly make a stink about it.
We need to paint before moving in, but I don't want tot waste my time and money by ignoring the hideous caulk issue.
Short of cutting out the miles of bad caulk and replacing it before repainting, is there anything I can do?
Thanks,
W
WoodySoCo is offline   Reply With Quote
Old 04-03-2011, 07:28 AM   #2
Woody, is the caulk cracking or does it look like it's peeling away from the edges, big difference. When the heat comes on in the winter, the trim will lose some moisture and contract which will cause cracking that looks like a split right in the middle. This is normal, unsightly but normal. In the summer the wood will swell and should minimize. If it looks like it's curling or pulling away at the edges that would be from caulking before prime.
That would require removal for a proper job. Post a pic.
Old 04-03-2011, 09:25 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Most times you can just put a nother bead of better quality caulk to fill in the cracks.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-03-2011, 04:59 PM   #4
You are correct, the caulk is pulling away from either the wall or the trim, but it is not splitting in the middle of the bead of caulk.
Where it has pulled from the wall it has paper stuck to it. Where it has pulled away from the trim it has pulled off of the preprimed trim.
Could this have something to do with the house being kept too cold (low 50s) during the winter?
Oh, and I found tubes of the suspect caulk - DAP Alex.
Today I spent 3 hours cutting out bad caulk and sanding baseboard today, and I only did about 30 feet of it.
I found that a 1" wide sharp chisel and utility knife were the tools of choice. I sanded with the 80 grit Norton paper with the whitish coating and blue backing, and it just shreds the latex paint and caulk right off the woodwork.
Starting to find great big runs and sags on the walls. Looks like a rookie painter got ahold of the spray gun and primed it like he was hosing down his kids with a super soaker squirt gun.
Old 04-03-2011, 05:17 PM   #5
That could be an explanation, the cold. However, if it's in/exterior caulk, it shouldn't be. I've never had good luck with any DAP caulk. I think a breakaway knife is better for cutting bad caulk than a utility. It's longer and more flexible which allow to run the blade parallel to the wall and slice the caulk off, which reduces the chances of drywall damage requiring patching. Prime it sand it caulk it paint it. Don't use painter's caulk, use a siliconized caulk. It's a bit** I know, good luck with it.
Old 04-03-2011, 05:32 PM   #6
Can you recommend a particular caulk?
Thanks for your time!
Old 04-03-2011, 06:30 PM   #7
Depends what's available to you. If you have a brand store, like BM or SW, or a hardware store, go in and tell them you need a good siliconized caulk. It doesn't need to be eight dollar caulk. As long as it's siliconized, or urethane, and paintable, you're okay. Check the paint ready time on the back, I bought a tube of BM urethane, black tube, had an eight day paint time. See Ya to that one. You should be good to go. Have fun.
Old 04-04-2011, 03:13 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
VERY important.
Old 04-04-2011, 07:12 PM   #9
DAP Dynaflex 2300 hold up well?
Old 04-04-2011, 07:38 PM   #10
Not familiar with but it sounds impressive.
Edit: Found this post on another forum for professionals
"What exterior caulk for stucco do you use? Cracks, and in between wood frames and stucco? (if not stucco, what's your favourite exterior caulk?
PS....if you mention any product by DAP you have to sit in the corner with a DAP CAP.
PPS....all mentions by DAP CAP'ers will be ignored."
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Contractor pre construction retainer scorpious Off Topic 3 07-29-2010 11:32 PM
Finish failure SidingHell Off Topic 5 05-20-2010 02:00 PM
