Interesting DIY Article - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 09:43 PM   #16
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 848
Originally Posted by jsheridan View Post
And lids.
Sir MixAlot is offline   Reply With Quote
Old 04-21-2013, 09:43 PM   #17
Gives me a good idea for a practical joke. How many of those can you get apart?
Old 04-21-2013, 09:55 PM   #18
Rewards Points: 5,974
Not sure which "guys", the pro pan or pro bucket, you are talking about, but it's just a matter of preference and job situation/requirement. If the day's material is 2-3 gallons a pan is fine. If it's 2-3 fives of material to be rolled then a bucket and grid are called for. I don't do a lot 2-3 fives of material jobs. If Mixalot is backrolling, someone is spraying, and sprayers are working out of fives, not single gallons. If the entire two coat job only requires one to two gallons a bucket is way overkill, IMO.
What I meant was it's different because being around paint a lot and being a diyer that is not so familier with the procedure and is probably more apt to run into problems like spills and drips.
Old 04-21-2013, 09:57 PM   #19
Rewards Points: 848
All of them.
Old 04-21-2013, 10:31 PM   #20
Rubbin walls since'79
Brushjockey's Avatar
Originally Posted by ToolSeeker View Post
One thing you guys are forgetting is you are painters and work with paint all the time.
Got a kick out of sir mix's bucket collection!!
One thing DIY's should consider- guys who work in paint all the time get it figured out- so you don't have to..
Ya know - why reinvent the wheel and all.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
jsheridan (04-22-2013), Sir MixAlot (04-21-2013)
Old 04-22-2013, 05:29 AM   #21
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Originally Posted by Sir MixAlot View Post
All of them.
I think he meant the buckets. Have you ever tried to get them apart?
The Following User Says Thank You to chrisn For This Useful Post:
Old 04-22-2013, 06:22 AM   #22
Seems that once used, no matter how well you clean them, buckets seem to want to bond together. I know that from only having twos and threes of them together. With that astronomical number, I'd venture to say a zillion of them are fused, lol. Maybe that's another use for WD-40, lol, lol.
Old 04-22-2013, 07:57 AM   #23
I have found a little dish soap will usually let you pull them apart. But I don't know about that many buckets.
Old 04-22-2013, 08:07 AM   #24
Rewards Points: 101
I've used the metal grid on a few occasions. Now I only use 9" rollers in small closets so there's just no need. Everyplace else I go with an 18" roller and use a large plastic pan.
JMDPainting is offline   Reply With Quote
Old 04-22-2013, 05:44 PM   #25
chrisn's Avatar
Rewards Points: 122
I'm with you. I keep maybe 4 or 5 old paste buckets for various uses around the yard and when it comes time to get them apart, well, you know. Wd 40, dish soap banging them with a 10 lb sledge, nothing seems to work very well.
Old 04-22-2013, 06:25 PM   #26
Rewards Points: 848
You guy's under estimate me.
All of the buckets come apart. And if a couple of the bottom ones are stuck, I know how to get them apart real quick.
While your throwing your buckets in the land fill.
I clean mine and donate all of them every year to a youth mission that takes them to third world countries, where a five gallon bucket is as like gold.
The Following 3 Users Say Thank You to Sir MixAlot For This Useful Post:
Brushjockey (04-22-2013), forcedreno2012 (04-22-2013), ToolSeeker (04-22-2013)
Old 04-22-2013, 06:39 PM   #27
That's admirable Sir. Good for you.
Why, do they use buckets and grids over there too, instead of pans?
Sorry, I had to do that.
Old 04-22-2013, 06:42 PM   #28
Renovating My Land Yacht
Rewards Points: 616
Sir MixAlot, Good for you for thinking "outside the bucket"
Can you share the youth mission details? I may have another bucket hoarder in the area that could help out.
forcedreno2012 is offline   Reply With Quote
The Following User Says Thank You to forcedreno2012 For This Useful Post:
Sir MixAlot (04-22-2013)
Old 04-22-2013, 07:09 PM   #29
Rewards Points: 848
That would be great. http://www.teenmissions.org/
Maybe they are affiliated with a mission in your area.
Old 04-22-2013, 07:46 PM   #30
Bucket hoarder...lol!
I was wondering what you had in mind for them- I could see that as pretty cool.
i wonder how shipping them is actually cheaper than just buying them there- but i'm already overthinking it..
This Should Prove Interesting Bud Cline General DIY Discussions 21 09-30-2011 06:53 AM
Trying to find a great long article on home maintenance wildturkey101 General DIY Discussions 8 07-12-2011 01:34 AM
Demand Load Calculations sirsparksalot Electrical 6 05-10-2011 06:42 PM
article regarding placing a deck on a roof Grumpy Roofing/Siding 1 09-19-2009 12:10 AM
Interesting article on DIY disasters J187 General DIY Discussions 1 11-27-2006 03:23 PM
