Insulation Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 05:05 PM   #1
Insulation Paint
I have seen a paint advertised that says it's an insulation paint - it keeps the heat from escaping.
I have a foyer that is extremely cold. I am in the process of replacing a door which may be adding to the problem - but the walls are very cold.
on side is the garage side - and I'm thinking of putting some insulation on that side of the wall --- but the outside wall is very cold as well. SHort of removing the drywall to see what's under it I was thinking of using this paint.
Has anyone ever heard of it.
Thank you.
Marie
mariefyfe is offline   Reply With Quote
Old 03-14-2009, 05:14 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
We discussed it a while back. The general concensus was that there is no way paint can insulate worth a hoot. It may seal a crack or too but that's abotu it.
Old 03-14-2009, 05:29 PM   #3
Remodeling Contractor
This treatment used what is called "therma-cells" These white powdered additive for paints is used as a heat reflecting property. So it helps keep a building cooler by reflecting direct sunlight but will do nothing for a cold wall.
Old 03-14-2009, 11:18 PM   #4
Thank you both very much! I was reluctant to buy something that wouldn't work. And I had my doubts about it.
Your quick response is greatly appreciated.
Marie
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
