Installing And Painting Moulding - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 09:58 AM   #1
Rewards Points: 310
installing and painting moulding
Hey all - our basement drywall was just sanded so were ready for paint/trim. My question is in what order we should do it.
I'm using MDF for the trim. It will be brown. The walls will otherwise be off-white.
  • So should I cut and install and caulk all the moulding now? Then paint it brown - then come back and paint over any brown overpaint with the wall color? I'm worried that if there is brown overpaint or mistakes, it would take a few coats of the off-white to fix it up.
  • Or should I pre-paint the molding brown on sawhorses, install, caulk, then repaint/touch up nail holes and the caulk -then paint the walls?
  • Or should I totally paint the walls -then carefully install and paint the trim once it's up?
Given the dark/light contrasts between the paints - I'm thinking that might have something to do with the order this comes together.
denemante is offline   Reply With Quote
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-19-2011 11:51 PM
painting my floor Eli Flooring 3 03-20-2011 04:11 PM
Painting Crown Moulding LeviDIY Painting 3 08-18-2010 01:28 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Painting MDF crown moulding sk8z Painting 3 05-19-2008 04:11 PM
