Old 03-23-2008, 09:52 PM   #1
Industrial Paint Stripping Question
Hey yall. I am about to start removing thick chipped paint chunks and such from two large crown mouldings I have on the exterior of my brownstone. I noticed that here in NYC specifically in soho when they want to strip the paint off of large exterior areas quickly, they apply some sort of adhesive sheet that sticks to the surface and latter gets peeled I believe, loosening all of the paint.
Was this a dream I had last night or do they make something like this? I believe the sheets were yellow with a repeated logo GP?
Any thoughts on where to get them would be helpful as well..
elephantbk is offline   Reply With Quote
Old 03-23-2008, 10:51 PM   #2
I'm not familiar with the adhesive strips, but a great paint stripper is Multi-Strip. It's fairly environmentally friendly (don't need respirator) and works great. It's not cheap, but works. It is a messy job, so cover everything and put down plastic and newspapers to collect all the dripping paint. (Also, this alleviates concerns about lead paint, as you are not sanding or releasing dust into the air). Good luck
Allison1888 is offline   Reply With Quote
Old 03-23-2008, 11:43 PM   #3
thank you!!
Old 03-24-2008, 12:50 AM   #4
Pro Painter
There are a couple of products like that on the market. I've never used them, but I suggest you do a search.
The paper seals out the air, and for an exterior, that's a good idea.
Stripper doesn't work so well in direct sunlight and the wind dries it out too fast.
But, to answer your question, yes they do make a product like that.
joewho is offline   Reply With Quote
Old 03-24-2008, 05:42 AM   #5
http://www.paintremoval.com/Qstore/c000004.htm
mark942 is offline   Reply With Quote
spray paint dry time question joeyboy Painting 12 01-15-2010 06:21 AM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
question on crappy paint job?? Doug Crf Painting 5 05-29-2006 10:52 PM
Stripping old paint off interior doors ? Scott_K Painting 9 05-12-2005 10:05 AM
