If Ya Mixed Two Paint Lines... - Painting - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 07:45 PM   #1
Rewards Points: 89
If ya mixed two paint lines...
...what's the worst that could happen? Customer has a quart of Aura Bath and Spa (matte) left and about 3 quarts of Regal Select (matte) in the same color. They want me to paint a small bedroom and I think we could get it done in a gallon.
I've never done this before and haven't mentioned the idea to the customer, but it would save them a decent chunk of change.
7.62 is offline   Reply With Quote
Old 11-06-2013, 07:51 PM   #2
Rewards Points: 13,764
Near impossible to match if you run out of paint and have to get more. In the middle of the job.
Old 11-06-2013, 07:57 PM   #3
Rewards Points: 512
i'd mix them up real good and use it if you know you'll have enough. worst that can happen is that your short and you have to buy more. and in that case you'll have to paint 1 full coat again.
princelake is offline   Reply With Quote
Old 11-06-2013, 08:15 PM   #4
Gymschu's Avatar
Rewards Points: 854
I've done it before. It's nice to have some Floetrol to make it more workable and to ensure you have enough……..
Old 11-06-2013, 09:04 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
What they said.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 11-06-2013, 09:11 PM   #6
Originally Posted by 7.62 View Post
... but it would save them a decent chunk of change.
Is your profit margin really That tight on this job??
jponto07 is offline   Reply With Quote
Old 11-07-2013, 04:42 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
I wouldn't do it, you should not be worried about the cost of the paint anyway
The Following User Says Thank You to chrisn For This Useful Post:
Live_Oak (11-07-2013)
Old 11-07-2013, 07:01 AM   #8
Rewards Points: 4,796
According to the manufacturers, the answer is going to be "unknown".
It's hard to imagine anything going wrong, but on the off chance it does, you'll be repainting it. I've seen inexplicable things go wrong before. But I'd try it.
As far as matching in the future, it would be no harder than matching paint on a wall where you don't have the original paint to begin with.
jeffnc is offline   Reply With Quote
Old 11-07-2013, 07:39 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
I have done it in the past. Boss kept switching suppliers on us. Never had an issue. Maybe we got lucky?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-07-2013, 09:40 AM   #10
custom user
Rewards Points: 150
I've mixed all kinds of paints, as long as it was water to water and oil based to oil, I didn't worry about it, this was mostly outdoor stuff but interior work as well. Never had a problem, some didn't mix well so I didn't use them.
That said, if you don't get it done with the one gallon, you're screwed and will have to start all over again. Probably at your expense. I don't see how it's going to save them a decent amount of money either.
JasperST is offline   Reply With Quote
Old 11-08-2013, 06:04 PM   #11
Painting Contractor CT
Rewards Points: 77
Post
Mix them up really well and you should be good to go... good luck!
KD PAINTING is offline   Reply With Quote
Old 11-09-2013, 08:54 AM   #12
Rubbin walls since'79
Brushjockey's Avatar
Where I have used this is for first coats to change a color. I will mix leftover paints close and the final will be the real thing. Sometimes it's still not worth it if the final has any thin spots or the first color wasn't close enough.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-09-2013, 09:19 AM   #13
Jmayspaint's Avatar
Rewards Points: 534
".....what's the worst that could happen"
The worst thing is that you void any product warranties. Mixing two different paints takes any responsibility for potential product failure off of the manufacturer and onto you..... How big of a deal that is varies depending on the particular job/client.
I have done it many times myself and never had a problem... Outside of those mentioned like not having enough and needing to match the mix.
Jmayspaint is offline   Reply With Quote
Old 11-10-2013, 03:01 PM   #14
I do this a lot. To tint a primer. Or just mix leftovers together for block fill or priming.
M_bisson is offline   Reply With Quote
Old 11-16-2013, 06:17 PM   #15
Rewards Points: 77
Paint mixing
Habitat for Humanity mixes used latex paint in 50 gallon drums and uses it for their houses.
http://hfhkp.org/index.php?page=paintprogram
chiraldude is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
what to use to paint over paneling and also hide paneling lines? Lorretta Painting 4 07-02-2011 10:30 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
