Ideas For Repairing Old Tongue And Groove Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 05:22 PM   #1
ideas for Repairing old tongue and groove ceiling
I have a 2x6 t&g sheathing that makes up our ceiling. I think the builder used wood putty between the cracks 50 years ago. looks like someone came along 6 years ago with caulk and filed in the groove. now its cracking again. anyone have an idea how to fill the cracks and prevent future cracking as much as possible. the only picture I could find I was testing possible coverups. I would rather use a filler or caulk.
Restyle is offline   Reply With Quote
Old 12-05-2011, 05:34 PM   #2
DIY staff
Rewards Points: 7,174
Those boards move way to much during the year to stop the gaps from opening up---
What kind of look are you trying for?
Might be easier to cover the boards up---
tcleve4911 (12-05-2011)
Old 12-05-2011, 05:42 PM   #3
I just wanted it to look cleaner without the cracks. I don't know if it can support to weight of drywall, but that would be the best looking way to go. I may have to use those pine 1 by 1/4 strips to hide the seams if its going to crack again in a year. Or beadboard and an inch of insulation.
Old 12-05-2011, 05:46 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Looks like the T&G boards are laying on top of the beams?
They can easily support drywall.
That looks to be around 2 feet or so between bays?
I would carefully cut drywall to fit in between and use a cove molding around the perimeter to cover the edges and the screws.......
Done.!!!!!!
tcleve4911 is offline   Reply With Quote
Old 12-05-2011, 05:53 PM   #5
I have 32" between beams. 5/8 drywall? Can I insulate with styrofoam panels without leaving space between insulation and sheathing.
Old 12-05-2011, 06:23 PM   #6
DIY staff
You could make a foam and drywall sandwich---I've done that several times without a problem--
Old 12-05-2011, 06:45 PM   #7
Ok I screw 5/8 drywall to the t&g with an inch of foam board between. cove molding for the edges. moisture wont cause a problem and the weight isn't an issue.
The Following User Says Thank You to Restyle For This Useful Post:
oh'mike (12-06-2011)
Old 12-06-2011, 07:06 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Why 5/8" ?
why not 1/4" ?
one inch foam is good
that much of a span will require screws in the middle that will get spackled and sanded smooth for paint
You're on the right track
Keep us posted with your results.......
Old 12-06-2011, 10:02 AM   #9
Rewards Points: 12,804
For this one I would not go any thinner then 1/2. The reason being is I feel with the foam behind it using 1/4" the screws would be hard to keep from poping through the sheetrock.
I use 1/4" lots of times when covering old plaster walls but there's something solid behind it for more control on depth.
Also with a thicker sheetrock you would need less screws to hold it up, so there's less finish work.
Old 12-06-2011, 10:06 AM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
sure...but 5/8" ?????
The 1/4" was just a thought for ease of handling......
...and I've used that over foam ...no problems
Old 12-06-2011, 11:46 AM   #11
Old 12-06-2011, 11:55 AM   #12
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 01:14 PM
tongue and groove ceiling robbet10 Carpentry 5 11-06-2011 12:38 PM
tongue and groove ceiling heathm3 Off Topic 1 04-06-2010 05:36 PM
Tongue and groove patio ceiling nailers Dave DB Carpentry 7 08-05-2009 01:46 AM
Heavy Dust & Tongue & Groove Ceiling Fix bobricci Flooring 4 11-08-2008 09:47 PM
