I Used Ceiling Paint Instead Of Primer By Mistake - Painting - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 07:16 PM   #1
I used ceiling paint instead of primer by mistake
Hi,
I'm new to this but I just found this chatroom and I need help. I took off some wallpaper from a bedroom and took all of the old glue off. I had nice smooth plaster to work with. I then put some primer on the walls. I went to get the ceiling paint to paint the ceiling and I was shocked when I saw that I had primed the walls with the flat ceiling paint by mistake.
What a mistake, but now what can I do. Can I go ahead and paint the walls as I was planning? What will happen?
Is there somehing I should do instead?
Thanks for the help,
Mike
SOCCERDAD is offline   Reply With Quote
Old 03-23-2009, 10:26 PM   #2
Rewards Points: 506
If you completely got the glue off the wall, nothing will happen at all. You can topcoat with the proper paint of your choice, no need to even prime. If you failed to get the all the glue off, the paint won't hold. If this is the case scrape off the failing paint, topcoat with Gardz, prime, and then topcoat.
SirWired
sirwired is offline   Reply With Quote
Old 03-24-2009, 01:24 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The ceiling paint will eventually migrate to the ceiling because that's where it wants to be.......
Old 03-24-2009, 07:20 PM   #4
Thanks Sirwired, that's what I did and it should be fine then.
Old 03-25-2009, 06:36 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Latex paint over oil primer - did I mess up? wrighter Painting 2 10-21-2008 02:25 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
