-   -   I used ceiling paint instead of primer by mistake (http://www.diychatroom.com/f4/i-used-ceiling-paint-instead-primer-mistake-40956/)
SOCCERDAD 03-23-2009 07:16 PM
Hi,
I'm new to this but I just found this chatroom and I need help. I took off some wallpaper from a bedroom and took all of the old glue off. I had nice smooth plaster to work with. I then put some primer on the walls. I went to get the ceiling paint to paint the ceiling and I was shocked when I saw that I had primed the walls with the flat ceiling paint by mistake.
What a mistake, but now what can I do. Can I go ahead and paint the walls as I was planning? What will happen?
Is there somehing I should do instead?
Thanks for the help,
Mike
sirwired 03-23-2009 10:26 PM
If you completely got the glue off the wall, nothing will happen at all. You can topcoat with the proper paint of your choice, no need to even prime. If you failed to get the all the glue off, the paint won't hold. If this is the case scrape off the failing paint, topcoat with Gardz, prime, and then topcoat.
SirWired
Matthewt1970 03-24-2009 01:24 AM
The ceiling paint will eventually migrate to the ceiling because that's where it wants to be.......
SOCCERDAD 03-24-2009 07:20 PM
Thanks Sirwired, that's what I did and it should be fine then.
chrisn 03-25-2009 06:36 AM
If you completely got the glue off the wall, :yes:nothing will happen at all.
