I Use A Roller But I Get A Patchy Rough Finish - Painting - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 06:59 PM   #1
I use a roller but I get a patchy rough finish
Hi
I am using a Maxim 9" roller medium pile, woth Dulux Matt paint.
I am starting to get a finish that is still smooth, but with patches that look like rough sandpaper.
I have done one bedroom and ceiling several coats, and two walls and cieling several coats, front room with the same sleeve.
I wash out the sleeve and leave it near a radiator to dry, after each coat.
Could that be the reason for the patchy finish, if so should I throw the sleeve away now.
I have a new sleeve and I notice that seems to be so much softer, is that likely to give me a smoother finish.
I hope someone can help, I am determined to get this right.
I will give it one more go this weekend, so I look forward to some good tips and advice.
Maxhammer
maxhammer is offline   Reply With Quote
Old 12-04-2011, 07:18 PM   #2
Gymschu's Avatar
Rewards Points: 514
It's more than likely your technique. A 1/2 inch roller nap is best. You can load it with lots of paint with each dip into the tray. Load that puppy up with paint. Your nap should ALMOST have paint dripping off it when you go to the wall. Let the roller do the work, don't press or push as this will leave marks in your fresh paint. Your paint choice may also be a problem. I have never heard of Dulux. Give Sherwin-Williams SuperPaint a try, you won't regret it. P.S. Wrap your roller sleeve in plastic if you plan on using the same color the next day. That way you aren't washing and drying (& wearing out) the roller sleeve.
Old 12-04-2011, 07:38 PM   #3
Hi,
Dulux is a top of the range paint in UK, good quality.
Re my technique I think that may be the answer, as i do tend to press very hard.
I will try it with a more lighter gentler strokes, and see if that solves my issue.
I did buy the Maxim 9" roller medium pile from advise, and it did cost me quite a lot withan extention pole.
A 1/2 inch roller nap is that thicker than the one that I am using, and why is that better.
I will need the sleeve to be able to fit the holder that I have, as I cannnot afford to buy another one.
Thanks for your help in this matter.
maxhammer
Old 12-05-2011, 05:03 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
You need to convert"medium pile" to American English
Over here the nap is 1/4 3/8 1/2 3/4 etc. inch. Sounds like maybe you have a 3/8, when a 1/2 would be better.
Old 12-05-2011, 05:39 AM   #5
Hi Chris,
Just to let you know that this for an interior semi skimed wall, that has several coats on.
But as said I have failed to get a smooth finish, withgout leaving the rough patchy marks.
Please copy and paste this link to see what I have: http://www.decoratingwarehouse.co.uk/buy/rollers-and-trays/9-paint-rollers--frames/maxim-9--professional-roller-kit/589
Trade kit Contains 2 x 9" Tiger stripe medium pile roller sleeves, 1 x 9" wooden handle cage frame (1 3/4" Diameter) with a screw type end. It also comes with a large 10.5", black plastic tray.This is a promotional kit and represents a saving on buying these items separately.
Can what the you tell me what the conversion to the 1/2 " nap is on that web site is, and tell me which one you would recommend I use instead.
I will then order that straight away, and hopefuly get that ready for this weekend.
Thank you so much for your help.
regards
maxhammer
Old 12-05-2011, 06:47 AM   #6
Max, sorry to hear you're having difficulty.
As to the thickness of the roller nap, (1/2) inch = 12.7 millimeters
You can measure the nap with your metric tape measure. From the picture it looks like it should be fine for a matte finish (but who knows how a matte finish translates).
It sounds like you may be rolling back into areas that have begun to tack up, or over rolling it. You can find some videos on rolling paint online, and I have some articles on paint rolling techniques under the And, more DIY Painting Articles link in my signature line, they may be helpful. Good luck chap, lol.
Joe
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (12-05-2011)
Old 12-05-2011, 07:32 AM   #7
Hi Joe,
Thanks for that although we in the UK also measure in inches as well as metric.
We seem to have a different term the US, we term it as medium pie etc.
I was tyrying to understand whether Medium pile is equivilant to 1/2" Nap in the US.
So if you think that medium pile would be enough to get a smooth finish, and so therefor It's more than likely to be my technique.
I will take a look at the link that you sent, and go from there.
Finally what do I do with the sleeve to keep it as new, do I wash it out and hang by a radiator to dry?or is the plastic bag best?
I will try to do this wall on Sat and Sun, so which method?
If it is week end or longer in-between, which method is best?
Thanks for your help in the matter.
Regards
maxhammer.
Old 12-05-2011, 07:44 AM   #8
chrisn's Avatar
Rewards Points: 236
Originally Posted by maxhammer View Post
Hi Joe,
Regards
maxhammer.
You need to get one of these( roller cover spinner) if you are planing on painting very much. The plastic bags works for over night storage, maybe a day or two
Old 12-05-2011, 09:57 AM   #9
Hi,
Can you tell me if I should sand down the rough patches, before I attempt to make good the next and hopefuly last coat.
What is the roller cover spinner for?
Many thanks for all of your help.
Regards
maxhammer
Old 12-05-2011, 05:30 PM   #10
chrisn's Avatar
Rewards Points: 236
Hi,
can't hurt
Regards
maxhammer
aaah, spinning out the cover to get it dry
Old 12-05-2011, 05:51 PM   #11
Hi,
Thanks for all of your help, that leaves me with lots to think about.
I will get down to it, at the week end.
Any more problems, and I know where to come.
Regards
maxhammer
Exterior Painting-Brush or Roller? Smokin Gun Painting 8 07-12-2011 05:02 AM
Restoring finish on conrete driveway and walkway... jdrunbike Building & Construction 5 05-18-2011 08:05 AM
What type of FINISH for a SMOOTH Finish? jennyusmc Painting 10 03-06-2011 06:59 PM
Newly refinished hardwood floors are too rough StevenSmith Flooring 11 09-25-2010 09:03 PM
to spray/power roll? putri Painting 10 07-20-2006 03:34 PM
