Old 10-29-2012, 01:44 PM   #1
I painted over wallpaper glue
I painted over wallpaper paste. How do I remove the paste and get back to a smooth wall surface? Condition now is irregular and somewhat rough. Any suggestions?
wardo is offline   Reply With Quote
Old 10-29-2012, 02:41 PM   #2
Gymschu's Avatar
Well, at this point all you can do is thorough sanding of the walls to remove the roughness. Wipe/clean off all the dust and then prime with Guardz primer. Repaint, done. If that doesn't work, well, you will be skimcoating those walls which is a much more involved process.
Gymschu is online now   Reply With Quote
Old 10-29-2012, 05:58 PM   #3
Mr. Paint's Avatar
I have seen 'burn-through' of starch from the paste that damages the dry paint film causing alligatoring and chipping. Try to sand off as much as possible before reproming, Like Gynschu said. Zinsser Gardz is excellent or an oil-based enamel undercoat.
Mr. Paint is offline   Reply With Quote
Hey let's paint over wallpaper glue DIY DUDE Painting 16 01-10-2013 05:49 PM
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
Removing glue on wall from wallpaper cwest94 Painting 6 01-25-2010 05:08 AM
paint over wallpaper glue? drewhart Painting 5 11-04-2009 04:18 AM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
