I Need To Stain Cabinet But Wood Varies From Light/dark - Painting - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 10:36 PM   #1
I need to stain cabinet but wood varies from light/dark
Hi all, I just joined the forums here. I'm a carpenter and I'm competent with wood working but I'm not a painter. I'm not very good with paint (becuase I usually make a mess) and I hate doing it, therefore I've avoided it all my life & I have little to no experience with painting & staining.
But at the time I'm out of regular work & helping my mother redo her 2 bathrooms in her house. I've been building her a cabinet & at the moment i'm constructing the face frame. It's going to go wall to wall & the face frame is made with 1x3 rails & styles of red oak. But on the ends the styles will need to be about 3-4" each so a 1x3 wouldn't do. I bought a 1"x6"x6' and have already cut it down to make the end styles but as I dry fit these end styles on I see that while they are the same type of wood as the rest of the face frame (red oak), the styles are a much darker red tone than the rest of the face frame which is lighter & paler. It's all unsanded & unfinished. I haven't put the end styles on yet.
I was planning on using a moderately dark stain. I'm wondering if after the stain is on if it will all look ok? As it is, dry & unfinished, it seems to clash. I just hate to spend another $20 because the board is the wrong color. I've already made two different $20 mistakes which were completely bone-headed moves on my part and I don't want this to cost my mother more than it needs to.
If it doesn't look better after stained then, isn't there a way to darken or lighten the parts to make them a closer match?
P.S. I haven't bought stain yet, so I haven't yet made any samples.
thx to anyone that helps,
gus
smally is offline   Reply With Quote
Old 06-03-2010, 06:16 AM   #2
DIY staff
Rewards Points: 7,174
Try a sample--oak takes stain well---My guess is that the variation will be acceptable.
Flecto (Varithane) has little ketchup packet sized samples at .25 cents each--Menards has Flecto in this area.
All you can do is try--You already cut the board--Give it a shot---Mike---
Old 06-03-2010, 10:20 PM   #3
Well, I finally found the answer to my own question. I thought I'd post the link in case anyone else is needing to know or interested. Now I just gotta find this stuff so I can get back to work
http://www.woodmagazine.com/material...h-wood-bleach/
Hope that helps someone else.
BTW before I found this, I went into the lowes today & brought some scrap pieces of wood. I played around w/ some stains & decided to go w/ Minwax's dark walnut. But I had a piece of the 1x6 (which was very red) & also a couple scraps of 1x3 (that were not nearly as red). Once stained when the 2 pieces were next to each other they still stood out, so I guess I need to bleach the 1x6 styles before I finish the face-frame.
Old 06-04-2010, 05:21 AM   #4
DIY staff
Be careful with that wood bleach--It will completely change the way the wood takes the stain--
It usually leaves a yellow cast to oak---Experiment.--Mike---
Looking for suggestions on kitchen cabinet stain color.....pictures attached Rhizzlebop Interior Decorating 15 04-05-2010 02:43 PM
Bullseye 1-2-3 or Cover Stain for bare interior wood? cej22 Painting 5 07-09-2009 03:09 AM
How to pick a wood stain? integlikewhoa Flooring 2 06-15-2009 09:50 AM
Stain Brochures vs Wood Samples rjordan392 Painting 5 04-08-2009 05:28 PM
Help! Our contractor made our kitchen cabinet door stain TOO ORANGE! Nikki99 Painting 12 11-19-2007 11:45 PM
