I Need Some Goo Removing Experts(sticker Scum) - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 10:59 PM   #1
Rewards Points: 36
I need some goo removing experts(sticker scum)
Hello DIYers, another trip to the think tank. A buddy of mine purchased a trailer, one of those big ones used for hauling race cars. He wants to sell it, and one of the potential buyers made him a nice offer, as long as all of the stickers were removed. So, we went to work with heat guns and razor blades and got all of the stickers off. This is on an aluminum surface. The glue left behind is another story. We have tried laquer thinner, gasoline, paint thinner, goo-gone, heat, etc. Nothing works. Any ideas from the painters? Thx in advance.
Tom
tompatrick is offline   Reply With Quote
Old 02-23-2012, 11:10 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Adhesive residue remover?
titanoman is offline   Reply With Quote
Old 02-23-2012, 11:12 PM   #3
Missouri Bound's Avatar
Call around the sign companies. They use a decal adhesive remover. You may find it in a good automotive supply shop, where they sell auto paint.
Do you want it your way or the right way?
Old 02-23-2012, 11:16 PM   #4
Rewards Points: 36
Thx titanoman, tried it, no dice
Old 02-23-2012, 11:23 PM   #5
Disabled wood vet
titanoman's Avatar
How about:
http://www.googone.com/
Old 02-23-2012, 11:29 PM   #6
Originally Posted by titanoman View Post
The OP already tried that (read post #1)
Give this a try.....................RustOleum.com
Old 02-24-2012, 04:09 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
or this, it is better than goo gone
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (02-24-2012)
Old 02-24-2012, 07:20 AM   #8
Too Short? Cut it Again!
I like Goo Off too. I have had good luck with the spray bottle version of Goo Gone in GEL form but never liked the liquid much. Oops is another brand. Krud Kutter sometimes works.
In days past, I used to have rubber cement thinner on hand (you can get it in quarts and gallons at an art supply store). It was great at getting adhesive residues off. It is not oily like others mentioned but evaporates quickly though so it will not do you much good on a hot exterior surface. I remember especially getting residue from baked on window parking decals loose in record time. It is great for getting tape residue from poster corners and so forth off walls because it does not leave an oily residue.
Check an auto parts store for gasket and adhesive removers they might have.
Some have had luck using WD40 for sticker removal.
Get some plastic razor blades so you don't scratch up the aluminum. They are handy to have around for other things.
Of course you know to use all of these things only with adequate ventilation.
Please post what finally works for you. We all come across this situation.
Old 02-24-2012, 07:42 AM   #9
Gymschu's Avatar
Rewards Points: 480
Goof off has always worked for me. You may want to apply some, then cover it with plastic rap so it can marinate for a while. Test it on an inconspicuous spot......you don't want to ruin the trailer! If you can find the gel version of Goof off that's even better as it stays put.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 02-24-2012, 07:51 AM   #10
How about water?
Old 02-24-2012, 06:19 PM   #11
chrisn's Avatar
Rewards Points: 228
I believe it will melt that
Old 02-24-2012, 06:35 PM   #12
http://decalstickerremover.com/
These work I have seen these démodé at trade show, they work as in video.
Hardway is offline   Reply With Quote
Old 02-24-2012, 06:40 PM   #13
How about water, and a scour pad?
Old 02-28-2012, 11:56 PM   #14
goo gone or greased lightning, maybe even try magic eraser?
Valerie1c is offline   Reply With Quote
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 07:22 PM
slow bathtub drain with yucky scum in tub redphoenix Plumbing 7 02-19-2011 11:29 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
