I Need Painting Advice - Painting - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 02:18 PM   #1
Question
I need painting advice please help!
I need to paint copper tubing, some copper fittings, and some pcv pipe. Is there a certain type of paint I should use on this project? If so please tell me
Mufasa02 is offline   Reply With Quote
Old 08-16-2011, 02:55 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Hope that is PVC pipe, PCP is something very different.
Almost any paint will work on the copper, the PVC is a little harder and is expands and contracts quite a bit. I recommend Krylon Fusion spray for the PVC ( it is made specifically for plastics). Walmart carries it. Use the fusion on the copper also.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Mufasa02 (08-16-2011)
Old 08-16-2011, 02:58 PM   #3
Thumbs up
Thank you your advice is much appreciated
Tags
copper fittings , copper tubing , paint , pcp pipe
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 10:32 AM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 08:56 PM
Painting Over New Apt - Need Advice stilllogicz Interior Decorating 4 04-12-2011 03:27 AM
Help. Need advice on cold and painting crisilee Painting 11 12-29-2010 09:15 AM
Newbie needs some painting advice bji Painting 8 12-26-2008 01:50 PM
