I Have 11 Interior 6-panel Doors To Paint - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 12:19 PM   #31
Sorry for resurrecting an older thread, but I'm in the same boat as Dave88LX: total sprayer noob. This thread is an absolute goldmine of information.
Originally Posted by ToolSeeker View Post
... I would recommend removing them to paint them. Use the big pieces of cardboard you had to practice spraying and maybe fashion a paint booth in the garage. If you have the room you can use say a paint stir stick or a piece of 1x stand the doors up screw the stick into the top of the door so they stand kind of accordion style then you can do both sides of 5 or 6 doors at a time.
Is this something I can do in my basement with proper ventilation? We're still getting cold weather here in Chicagoland, but I really want to get these doors painted. I'm getting tired of not having doorknobs.
Since I've seen it mentioned so often, I'm assuming I should invest in a Graco paint sprayer? I popped onto their website and thought maybe one of these would work for me.
Jeffreybomb is offline   Reply With Quote
Old 02-12-2014, 05:50 PM   #32
Rewards Points: 6,034
Is your basement finished or partly finished? If the answer is yes then no don't do in your basement. The learning process can be messy. But you can use your basement for a couple of smaller projects to learn on till you feel confident. Then fashion a sort of paint booth in the basement. Just be careful what you spray such as alcohol based primer in a closed space with the furnace kicking on is a no-no. Same with anything oil based. This is because these are going to be in such a fine mist as to be dangerous.
As for the sprayer I don't have either so let me suggest Paint Talk and use the search feature. They won't let you ask questions because it is for pros, but you can still search. If my memory serves me correctly one of those sprayers has some really bad reviews and one has good ones. But I can't remember which has the good ones.
Hope this helps. Good luck and feel free to ask questions.
Old 02-13-2014, 11:21 AM   #33
Thanks! My basement isn't finished, so I thought it would be a good spot to spray. I also found a set of four retractable spring posts that you can use to hold up tarp/plastic to make a sort of "spray booth." I'll probably pick that up, too.
Old 02-13-2014, 02:28 PM   #34
Good Luck and let us know how it works out.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 07:31 PM
What to do w/ old doors with 8 layers of paint on them? CoconutPete Remodeling 11 01-29-2010 01:52 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
