HVLP Gun Leaks - Painting - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 08:20 PM   #1
HVLP Gun Leaks
Hello,
I recently acquired a Graco HVLP 4900 procomp in non-working condition. I have completed the rebuild of the unit and everything works great now…but one little issue. I am getting a leak on the gun at what I believe is called the “Packing Nut”. It where is the needle goes into the front part of the gun in front of the trigger.
I did perform a rebuild of the gun – did I install the parts incorrectly? What would cause it to leak here and what should I try?
Jonathan
tidenumone is offline   Reply With Quote
Old 11-04-2012, 10:21 PM   #2
Rewards Points: 13,450
Just google the info you just posted on the make and model and look for a parts break down.
Is there burrs or a worn area on the shaft?
Old 11-08-2012, 07:02 PM   #3
Barry
The packing material in Graco guns typically consists of 5 plastic washers and a brass nut. The brass nut is adjustable, and controls the amount of drag on the fluid set (needle).
when you rebuilt the gun did you dis-assemble the packing and replace it? If not, you may just need to tighten down the brass nut a bit to take up the gap around the fluid set. Otherwise the old packing may be shot and need replacement. It's a pain to replace because there's 5 tiny plastic washers that are grooved and all have to fit together in the right direction.
Barry
Tub Refinisher is offline   Reply With Quote
Xypex or other sealant for foundation leaks MidgeTenant Concrete, Stone & Masonry 3 06-20-2016 06:58 AM
Painting kitchen cabinets, Wagner HVLP conversion gun? Cobrakillert Painting 24 03-27-2013 04:26 PM
Leaks on porch roof Pau-Latina Roofing/Siding 23 09-27-2012 02:36 PM
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
Spraying with HVLP ponch37300 Painting 4 04-20-2009 12:53 PM
