How And What Tools And Supplies You Would Use? - Painting - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By Colbyt
Old 02-17-2017, 09:28 AM   #1
How and what tools and supplies you would use?
How would you guy patch this wall and what would you use?
ccoaston is offline   Reply With Quote
Old 02-17-2017, 09:31 AM   #2
Re: How and what tools and supplies you would use?
pic attached to post
Old 02-17-2017, 10:40 AM   #3
Rewards Points: 3,863
I would remove all the loose material and square up the opening. Then I would shim / furr as necessary so that 1/2" drywall would flush to the existing surface. Fill any big voids with a Durobond style mud and then finish it with regular, sandable mud in multiple coats.
Gymschu, stick\shift and Marky82 like this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-17-2017, 03:55 PM   #4
Rewards Points: 14,026
#1, what caused all that damage?
That needs to be addressed first.
A 4" cast iron drain line running on an outside wall above a window!
What's holding up the roof?
No location in your profile so I'll guess an ice dam on the roof.
I would not waste my time trying to patch anything it all needs to come out and be replaced.
Old 02-17-2017, 04:06 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,992
The photo is rotated. Either that or the screwdriver on the sill is performing a neat trick.
lenaitch is online now   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
chrisn (02-17-2017)
Old 02-17-2017, 04:23 PM   #6
The pic is rotated. And why would I redo everything. It's how it was built. Is there a particular reason why you would pull it out??
Old 02-17-2017, 04:24 PM   #7
No ice dam on the roof. New roof was just replaced with a new roof.
Old 02-17-2017, 04:27 PM   #8
Here is a better view. It is in the kitchen
Old 02-17-2017, 04:33 PM   #9
jlhaslip's Avatar
Rewards Points: 2,820
In my part of the world, any plumbing in the exterior wall is a no-no. Period.
Add some insulation and vapour barrier as possible then drywall as per above.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-17-2017, 04:48 PM   #10
Usually Confused
lenaitch's Avatar
By the looks of things, the house was built under a very old code or pre-dates any code. If there is no insulation in the rest of the wall, a bit in this spot isn't going to do much good. As mentioned, secure some furring or something to fasten a piece of drywall to. It looks like the original wall is plaster so you'll probably have to build up the patch.
