How Well Does Solid (opaque) Stain Cover Knotty Pine? - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 05:51 PM   #1
How well does solid (opaque) stain cover knotty pine?
I have knotty pine as trim on my windows and I hate it. It doesn't really match my home so I was wondering what your experiences are with the solid (opaque) stains? How well do they cover wood grain-they say they will cover the grain completely but will they also cover the dark knots is I choose a lighter opague color such as a tan or gray base? I have heard that it's nearly impossible to cover the dark knots with paint. If anyone has pictures of projects using opaque stain over knotty pine or know of sites that have pictures of this please post if you can.
Thanks so much.
skidoo42 is offline   Reply With Quote
Old 11-25-2012, 05:57 PM   #2
Rewards Points: 14,312
Post a picture of what you have.
Want it to look perfect and not see any knots, then replace the trim with stan grade trim.
Old 11-26-2012, 04:47 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
prime and paint?
Old 11-26-2012, 05:35 AM   #4
Skidoo, knotty pine can be painted like any other. At least, the knots need to be sealed with BIN, a white pigmented shellac. Ideally, a full prime with shellac is best because tannin bleeds not only from the knots, but in areas throughout in a haze. It's a bit difficult to work with as a full prime as it dries very quickly, but help is here if you choose. You could however use BIN on the knots, another primer like Zinsser 123 on the rest, and just deal with any haze later as it appears. It may not, no pun intended.
After priming some knots may need spackling to make smooth. Patch them with some lighweight vinyl spackle, sand smooth, prime and then you're ready to paint the trim with the finish of you choice.
Check back with further questions if needed.
Joe
Old 11-26-2012, 08:14 AM   #5
Too Short? Cut it Again!
We are talking interior or exterior trim here? I ask because one would not normally consider a solid stain indoors.
Old 11-26-2012, 09:53 AM   #6
Good point!
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 08:37 AM
Solid Stain on Cedar Siding Researcher Painting 1 08-08-2010 10:11 PM
oil based solid stain for wood mira477 Kitchen & Bath Remodeling 1 07-18-2010 06:53 PM
Bullseye 1-2-3 or Cover Stain for bare interior wood? cej22 Painting 5 07-09-2009 03:09 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
