How Thorough The Sanding On Deck? - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 09:33 AM   #1
Rewards Points: 99
How thorough the sanding on deck?
Today I will start sanding the treated wood deck prior to its initial applying of Sikkens next week. Directions are to use 80 -120 grit. No problem generally.
Ques: the deck boards are the typical treated wood 6" wide with rounded edges. They are installed with min. of spacing (1/8"). So it is going to be difficult to get much sanding done on the rounded edges. Should I bother?
Concern: My belt sander might just mess up the factory rounded edges too much. Hand sanding the board edges on such a large deck is impractical.
What to do?
Hossenfeffer is offline   Reply With Quote
Old 06-17-2011, 01:20 PM   #2
Too Short? Cut it Again!
The major issue is going to be what the stain penetration and color difference ends up being like if you do not sand the edges. I doubt it will be that much of a problem but try a little test section to put your mind at ease.
Years ago I bought a new Dremel contour sanding kit for $10 at a parking lot inventory reduction sale. I think Dremel was trying to get $100 otherwise for the kit which struck me as a bit absurd. It is by no means a production tool but I do find it more handy than I ever thought for situations like you face. I use it a lot for sanding antique window frame details and so forth. As with anything Dremel the paper is expensive but I suspect Harbor Freight sells alternatives. You might check Amazon, eBay, etc. to see if something similar pops up at a decent price.
Old 06-17-2011, 06:47 PM   #3
Faron79's Avatar
Rewards Points: 260
IF it's not too late....
DON'T use anything higher than 80-grit!!
Especially on P/T wood!!!
Stain has a hard enough time soaking into some of that stuff...
>>> If I were you, I'd sand it to 60-grit. <<<
FORGET the belt-sander too!
(unless you LIKE punishment....)
Rent a 12"x18" Vibrating flat-plate sander.
Does it much faster and better than any other sanding-method.
Faron
Faron79 is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Sanding rough PT deck boards houseinthewoods Painting 2 06-24-2010 06:27 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
deck sanding, varnishing/protecting mcvane Building & Construction 3 05-09-2007 09:48 PM
