How To Tell If Current Finish Is Water Base Or? - Painting - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 10:52 PM   #1
How to tell if current finish is water base or?
My daughter just bought her first condo. The kitchen cabinets were gone over with a light white wash at some point. It feels like there is little if any "finish" coat. The wood is a little bit raw feeling to the touch. She wants to put a clear coat on them. Is it safe to put a water base clear coat? I know it won't stay if the under coat was oil base but I thought since it felt rough it may adhere well anyway. Is there a way to discern if existing stuff was oil or do I not even need to worry about it?
Thanks!!!
in2food is offline   Reply With Quote
Old 01-03-2010, 06:55 AM   #2
Remodeling Contractor
When in doubt use a primer first. A good acrylic primer and an enamel top coat will work fine. clean and sand the old finish first no matter what you decide to do.
Old 01-03-2010, 07:10 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
Rub it with goof off or denatured alcohol on a rag, if it comes off it is latex.
Old 01-03-2010, 08:07 AM   #4
Contractor
Induspray's Avatar
Acetone will also rub the latex off but will have no effects on oil or alkyd paints.
Probably doesnt matter what is on there, give a good light sand to remove the gloss, run over entire surface with tack cloths to remove dust and clear coat.
Induspray is offline   Reply With Quote
Tags
cabinets , clear coat , refinish
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
