How To Smooth Off Paint Edge? - Painting - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 06:07 PM   #1
Rewards Points: 33
How to smooth off paint edge?
Obviously painters tape is most often used to cover the edge of a wall or trim so that a nice straight line can be achieved, but what if the tape is used on the middle of the wall to create that straight line on the middle of the wall. If several coats of paint are applied then when the tape is removed this leaves a 90 degree edge were the paint met the tape. This is ok for a part of the wall that wont ever be touched but if I was to ever run a moist cloth across the wall to wipe it off it would catch this "edge" and possibly pull or chip some of the paint away. I know this isnt a likely scenario on walls but I just wanted to use it to get an idea for what options are out there for smoothing/rounding off this edge created at the point were the paint meets the edge of the tape.
konsole is offline   Reply With Quote
Old 10-18-2010, 06:33 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If there was enough of an edg to catch a rag or something then you have the paint too thick. Two thin coats is always better than one thick one.
Old 10-18-2010, 07:28 PM   #3
Rewards Points: 33
True for most applications, but I am applying more then 2 thin coats for my own reasons and will no doubt have an "edge" to deal with. LOL everybody always tries to fix what they think is wrong with what somebody is doing, which is fine, but ultimately they avoid answering the question. I appreciate the advice your giving me but it doesnt apply in my situation.
Old 10-18-2010, 08:19 PM   #4
Rewards Points: 101
With tape you're going to have an "edge" or line 90% of the time. I never use tape, something that has worked for me is to mark the line on the wall lightly with a pencil and cut it in free hand. If you're not an experienced painter with a steady hand it may be tough, not much more I can offer.
JMDPainting is offline   Reply With Quote
Old 10-18-2010, 09:12 PM   #5
Well what you do on your walls is your business.
You can always try some wet sanding with some 400 or 600 grit sand paper.
Old 10-18-2010, 10:19 PM   #6
Rewards Points: 526
Remove the tape, wait for the line to set up for a few weeks, then carefully run a sharp razorblade scraper perpendicularly down the line.
Windows is offline   Reply With Quote
Old 10-19-2010, 10:30 AM   #7
Rewards Points: 33
ya I figured carefully using a sharp blade is probably the best option, depends on how high the edge is. The other thing I was thinking of doing is using something thats stiff but very thin and angle it at 45 degrees to the edge of the paint and then just apply a good amount of pressure to it. Hopefully that would turn it from 90 deg to 45 deg. This new paint is a matte flat color and it borders a surface that has high gloss to it so using sandpaper or a blade or anything aggressive risks damaging the high gloss surface. I do have some 2000 grit sand sponges which I may try if I decide the thin blade wont work.
Old 10-19-2010, 05:33 PM   #8
dubinpainting's Avatar
This happened to me with the custom stripe in the picture. I would just leave it until you re-paint then sand the crap out of it. You might even have to skim coat. I just re-painted the stripe and I had to do this.
dubinpainting is offline   Reply With Quote
Old 10-19-2010, 06:36 PM   #9
Rewards Points: 33
which is fine for a surface that doesnt get touched but if I want to wash it then I run the risk of the wash cloth catching the edge. I wonder if there is some kind of crystal clear caulking? Something that stays kinda goopy and dries rock hard but can be easily removed until it dries.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
behr textured smooth paint leishadaniel Painting 1 07-06-2010 05:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Painting Fascia, should I paint the drip edge? PaulR Painting 3 12-19-2008 05:59 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
