-   -   How should I fix spots I missed with first coat? (http://www.diychatroom.com/f4/how-should-i-fix-spots-i-missed-first-coat-73464/)
vwchappy 06-11-2010 11:39 PM
Hi,
I am painting my living room and dining room walls the "Brown Buzz" color from Valspar (Lowes) I did one coat of valspar primer with the brown buzz tint inside lastnight, and tonite I did my coat of the paint. The roller wasn't totally wet with paint I could tell in some spots because you could see the primer through. Little blotches. I went back with just a brush and filled in those spots - now when it's all dry, I can see where I filled in. What should I do? I was thinking of rolling on another coat tomorrow, but I don't want to do the WHOLE thing again. Is it OK just to do a line with the roller where the blotches are, or will that new coat show much more and would it look worse?? If someone could help me that would be great. Thanks!
Matthewt1970 06-11-2010 11:42 PM
Try to do any touchups with a roller if you can but that can be tricky to do especially with glossy paint (even worse with eggshell) but you will probably have to do a whole second coat.
vwchappy 06-12-2010 12:08 AM
Should I worry about painting my edges first again or should I just get the majority with the roller? If just the roller is good enough, that's fine - I just don't want to have to do all the edges and box it in again
chrisn 06-12-2010 04:36 AM
You MIGHT get away with just rolling it all again but to do it right you really need to do a full second coat, which means cutting in again.:(
oh'mike 06-12-2010 07:06 AM
In my opinion--there is no such thing as a good -one coat paint job.
If you want a top quality job----always do to full coats.
Valspar is not an easy paint to get a top quality job,even with two coats.
Mike
DUDE! 06-12-2010 08:30 AM
Although I'm not a painter by trade, I do lots of painting. In the long run, to look good, I always paint two coats. I've never got my cut lines to cover good with one coat. And for sure in tight quarters, I might miss some with the roller. And as someone will always tell you that you "missed a spot" when painting, I reply that after 5 or 6 coats, you'll never notice it.
kwikfishron 06-12-2010 09:05 AM
199 Attachment(s)
The best way not to miss a spot is a well lit wall.
My dbl halogens are always blazing when I paint.
chrisn 06-12-2010 06:34 PM
Mike
That's for sure:yes::laughing:
