How Should I Approach This Room? - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 02:06 PM   #1
How should I approach this room?
Hello, I have a whole (factory primed) house interior to paint before I can move in. In this picture ( of a typical room) you can see it has trayed ceilings and double crown mouldings and recessed lighting.
So my thought is to roll everything (per previous advice) . From there it's not so clear.
I'm thinking I should just mask all the crowns first and then paint the (flat) ceilings then (eggshell) walls, unmask and paint the (semi gloss) crowns/trim with/without masked walls.
That's an awfull lot of masking though. (1000'?) Is there a better way/sequence? Should I paint the crowns first, then mask them and THEN do the ceilign/wall rolling? I have "medium" paint skills but don't have the best hand/eye for cutting in fine edges.
p.s. On the recessed lighting, should I just paint over the flat flange section flush with the ceiling to make it blend in or mask it.
All advice appreciated
Dave
weehooker is offline   Reply With Quote
Old 01-08-2012, 02:26 PM   #2
DIY staff
Rewards Points: 7,174
First thing---remove the light trims--they just unhook--Patch/sand/prime and damage
Next---Paint all trims--don't worry about getting trim paint on the walls or ceiling--
Then paint the ceiling---A $20--brush will make cutting easy enough that tape should not be needed.
Next---mask the top of the baseboards---(spatter mask)--Cut in the walls--roll--two coats are needed---avoid using poor quality paints---Use a top quality roller---
Old 01-08-2012, 02:29 PM   #3
Rewards Points: 13,468
I alway presand all the walls and ceiling with a drywall sanding pad, with sanding cloth on it. There's always going to runs or flaws that will need to be fixed before painting.
With any room you always start at the ceiling. Those trim rings just pull out once you remove the bulbs.
You better start practicing with a 2-1/2" trim brush. Much faster and will come out better with no peeled off primer if you cut in.
The ceiling, all the trim then the main walls is the order to do this.
Old 01-08-2012, 02:53 PM   #4
DIY staff
Thanks for catching that---New work (and most old work) Needs a quick light sanding to knock off any crud caught in the old paint job.
Old 01-08-2012, 04:23 PM   #5
Hey Weehooker, what colors are you using on the ceiling, walls, and trim in that room?
Old 01-08-2012, 09:52 PM   #6
Thanks Gents, I will follow your good advice. Trim first, then see how hard it is to cut in. Tape will be my last resort. ( Truth be told, the wife LOVES to paint trim but is "not big on neatness.. I need to figure out a way to do it myself.) I will also give it a quick sanding too.
Colors?? The wife is in charge of that but I believe the cieling will be flat white, the trim semi gloss white and the wall colors will vary but be ( Eggshell?) "earthy/craftsman" colors like greans, greys,tans,clay etc. I believe all doors and trim will remain white. The main space ( Living, kitchen and dinning) is slated for a light, moss green as I recall. That said, the factory primer ( on the ceiling) has a slight tan tinge to it. I kind of like that little bit of contrast with the white trim. I was thinking of keeping a little tint in the ceiling.
Thoughts welcome!
Old 01-09-2012, 06:39 AM   #7
Ceilings first, overlapping onto the crown molding
Crown molding, overlapping to to the walls
Sand the walls and trim, do it at this stage because there may be spatter from working overhead
Paint trim (no baseboards), overlapping onto the walls
Paint the walls, overlapping on to the baseboards
Paint the baseboard
I generally paint walls first, then trim. But, it can go either way, and I'll do trim-walls in certain circumstances.
Old 01-09-2012, 04:26 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
Paint the baseboard
I thought I was the only one left in the whole world that still does this
chrisn is online now   Reply With Quote
Old 01-09-2012, 05:48 PM   #9
Learning Things Every Day
Jay 78's Avatar
Is it really that uncommon? That's how I do it.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-09-2012, 06:07 PM   #10
I guess that I should mention that the baseboards are just tacked in at this point. I intended to paint them in the garage then install after the walls are painted and floors installed. ( Realizign I may need to calk them if the fit is less than perfect.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
advice/Help on non-permitted bonus room? Orange_County General DIY Discussions 43 06-11-2010 05:06 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
