How To Sand My Ceiling Without Making A Godawful Mess? - Painting - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 08:32 AM   #1
Rewards Points: 42
How to sand my ceiling without making a godawful mess?
Hi All,
After doing a lot of half-assed painting in my time, I'm ready to try doing a room properly. One of the things I've gleaned online is that giving the surface a light sanding first with a pole sander is well worth it. Are there any tips for sanding the ceiling in non-empty room (kitchen) without getting dust everywhere? I'm guessing that even with drop sheets it will be easy to get dust all over the place. . .
jerkbag is offline   Reply With Quote
Old 03-12-2014, 08:49 AM   #2
Rewards Points: 13,712
There should be hardly any dust.
All your trying to do is find any paint runs, fuzz from a cheap roller, high spots where the outside edges of the roller where.
A box fan sitting in the window facing out with the screen removed will help with any air bourn dust.
Old 03-12-2014, 08:57 AM   #3
Painting Contractor
Rewards Points: 155
I would cover floor and anything that would be hard to clean like stove, cannisters, etc. After sanding, just hit flat surfaces with cleaning wipe and you're good to go.
VAProPainter is offline   Reply With Quote
Old 03-12-2014, 09:08 AM   #4
Rewards Points: 42
Ah okay, sounds good. Never done before so I assumed it would be dusty as hell.
thanks!
Old 03-12-2014, 04:40 PM   #5
Gymschu's Avatar
Rewards Points: 832
These are pretty nice to have:
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
Danahy (03-12-2014), Jmayspaint (03-12-2014), rbriggs82 (03-13-2014)
Old 03-12-2014, 05:14 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
Yes, very nice to have. Much better than the old rectangle ones.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (03-12-2014)
Old 03-13-2014, 02:13 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
I can see no reason to be sanding a ceiling, unless there was a lot of patch work done.
The Following User Says Thank You to chrisn For This Useful Post:
Old 03-13-2014, 06:39 AM   #8
Rewards Points: 5,974
So now you want to do some full-assed painting. If it was previously painted then a light scruff sand should all that is needed, there should be very little dust. If it's more than that get a 3M hand masker and a roll of 9' plastic. Mask around the top of the walls then droop the plastic down over everything and if you cover the floor clem-up is very easy.
Old 03-13-2014, 08:29 AM   #9
Rewards Points: 42
I've read a few places that it'll look better if you give the wall a light sand, though perhaps that doesn't apply to a ceiling. In any case it doesn't sound like it will be too messy.
Old 03-13-2014, 03:46 PM   #10
Rewards Points: 4,796
Sanding a wall will only make it look better if it doesn't look smooth to begin with. Think about it. Let's say you sand a wall perfectly smooth, then put on a smooth coat of paint. Well, let's say you're going to put on 2 coats. Would you sand between coats? I certainly wouldn't. So what would change to that wall over the years that would require you to sand it? Not unless you made some patches to it as chrisn said.
Same thing applies to a ceiling. Now sanding drywall compound can be very, very dusty. But once it's painted, there will be very little dust. I wouldn't bother covering the walls. I'd just get the furniture out or cover it. Vacuuming the carpet afterward should be enough, or put down dropcloths if you'd rather.
jeffnc is offline   Reply With Quote
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Caulking Baseboard Without Making a Mess on the Walls digexpressions Painting 10 12-25-2007 08:31 PM
Painting kitchen ceiling making me crazy! Kay Gremban Painting 5 06-15-2007 01:03 AM
