Old 08-06-2012, 04:01 PM   #1
how to restore a plaster wall after wainscot removal?
I removed some fugly wainscotting that was glued to this plaster wall and it looks like a mess now.
Any idea how i should go about restoration to make it look plain and smooth without all the way abating and replacing the plaster?
how to restore a plaster wall after wainscot removal?-forumrunner_20120806_160053.jpg
Old 08-06-2012, 05:18 PM   #2
paper hanger and painter
chrisn's Avatar
Wow! You need to scrape off all the glue etc with a sharp tool, wall paper scraper, sharp chisel, whatever, sand it somewhat smooth, apply Gardz primer, skim coat with joint compound, let dry, sand, re apply JC, sand, clean, re apply Gardz, paint. Sounds like a lot but it will go pretty quick if you have done any skim coating before, if not, good luck.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
amakarevic (08-06-2012), sdsester (08-06-2012)
Old 08-06-2012, 08:17 PM   #3
sdsester's Avatar
Like Chris says it will be a bit of work but is doable.
There is no easy way to get the adhesive residue off.
Make sure you have or get a nice wide drywall knife for skim coating.
I like using repair plaster on plaster but compound would work---especially if you use dry mix/hot mud. Plaster and lightweight compound in particular can expand and shrink at different rates but your repairs are not too deep to worry too much. Drywall compound is easier to sand.
Gardz is definitely in your future.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
amakarevic (08-07-2012)
Old 12-30-2012, 05:19 PM   #4
How about if I just scrape what can be scraped and then simply apply Peel Away 1 -- I used it a couple of years ago to remove some stubborn paint off my basement walls before I exposed them. See the picture -- the circle was the test area before I did the rest of the wall, IOW the clean circle used to be as painted as what's painted around it. Do you think it is applicable here as well?
Old 12-30-2012, 05:39 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
The sheetrock is not as solid a surface as that brick, and you don't really want to strip the paint off- just get it smooth. And even if you did use peal away it would still be a rough surface that would need a skim.
So back to what chris said- ..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 12-30-2012, 06:01 PM   #6
it is not sheetrock -- it is an inch thick plaster over brick. the house is 100+ yrs old
Old 12-31-2012, 10:48 AM   #7
Peel away will not remove the glue. Paint is the least of the problem.
How to remove a faux fireplace from a plaster lath wall GarfE Remodeling 5 04-11-2012 08:40 AM
Taking Down a Plaster Wall. shane2 Remodeling 5 02-16-2012 11:37 AM
Wall Removal 1stclasso Building & Construction 4 02-12-2011 11:08 PM
Lath & Plaster Wall Box winesmile Building & Construction 2 12-03-2008 02:58 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
