How To Remove Wallpaper? - Painting - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 06:48 PM   #1
How to remove wallpaper?
I just bought a house that has lots and lots of old peeling wallpaper. I have managed to peel most of it off. A few walls have wallpaper that won't peel off because only the top layer of the wallpaper comes off, leaving the wall sticky. Any ideas on how to remove the wallpaper? Also, if I may ask another question. My husband and I have no idea how to coordinate colors. We are buying new tile and carpet and painting. Any suggestions on where to look for ideas. We want pretty neutral colors, yet not too boring. Also, our home is pretty small, so we thought light colors would be best. Any ideas? Thank you so much.
catlam is offline   Reply With Quote
Old 09-24-2010, 12:28 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Get a Zinsser Paper Tiger scoring tool. Also get their spray bottle of paste remover. Concentrated simple green works fairly well also. The main thing is to get it wet. The paper tiger is a real help as it makes many small holes for the water / remover to penetrate. It is still a lot of effort to get off some old papers. You can use hot water and a sponge to help get the glue off, again simple green in the water seems to help here. When dry you may have to give it a light sanding. Sealing it up with a coat of Zinsser Guardz is not a bad idea.
Colors - Don't go too dark. Reds are popular, but can look too dark unless a room is very well light. Don't be afraid to try some brighter fun colors.
Get quality paint. Use Sherwin Williams or Benjamin Moore. Use Benjamin Moore Aura line for hard to paint colors. Use a good purdy brush, wet it and wipe dry BEFORE you dip it in the paint. Use white dove, ez-care, or equivlent roller covers, around $4 each retail.
Get a cloth drop cloth not plastic.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 09-24-2010, 10:04 AM   #3
Rewards Points: 558
This is all you need to know on how to remove wall paper: http://www.youtube.com/watch?v=GiIYH4cMkN4
epson is offline   Reply With Quote
Old 09-24-2010, 11:14 AM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Score the wallpaper with a tiger shark, use a solution such as safe and simple which can be ordered on line, that's what we prefer to use. Follow the instructions, after removal wipe down walls with tsp or similar, apply an interior oil base primer, make any drywall repairs, prime any repairs you have made, then top coat with two coats of paint
housepaintingny is offline   Reply With Quote
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
To remove wallpaper or just re-drywall interplexr Painting 12 01-14-2010 01:48 PM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
Using Steamer to remove old painted over wallpaper saggdevil Painting 15 06-14-2009 06:22 AM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
