How To Remove Those Sticky Pads From The Wall? - Painting - DIY Chatroom Home Improvement Forum
Old 10-02-2009, 11:54 PM   #1
Rewards Points: 682
How to remove those sticky pads from the wall?
I have a message board attached to the door with these super sticky pads. Last time I removed them from the wall, there was this sticky residue that took forever to scrape off before I could paint the wall.
Is there an easier way to remove these sticky pads? Or am I doomed to just ripping off the paint?
darsunt is offline   Reply With Quote
Old 10-03-2009, 06:04 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I think GooGone will remove the residue, but ya, they are a pain in the butt.
Old 10-03-2009, 06:38 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 494
It will also remove the paint,if it is latex,but you really have no other option except manually scrape.
Old 10-03-2009, 08:54 AM   #4
Too Short? Cut it Again!
Goo Gone, Oops or Krud Kutter will work. I always used rubber cement thinner to take city windshield parking stickers off.
I personally hate anything people stick to walls. I would rather they hang things with railway spikes! I can patch holes in a fraction of the time it takes to deal with sticky stuff.
My primary gallery client uses the gallery goo stuff for attaching labels and I guess they do not have much of an option. The horrid material picks up oil from your hands though and everything I try---even the stain blocking primers---never wants to cover it completely.
Old 10-05-2009, 02:46 PM   #5
Remodeler
KlintP's Avatar
I've had luck with Goo Gone and a putty knife. The flat end of the putty knife works well to scrape it up.
KlintP is offline   Reply With Quote
Old 10-08-2009, 06:03 AM   #6
Gently use a heat gun (hair dryer) to soften the adhesive before scraping.
paul1149 is offline   Reply With Quote
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Can I remove dividing wall QuestionGuy General DIY Discussions 1 03-30-2008 03:32 PM
Want to remove wall found heating/ducts wondrgirl HVAC 2 06-04-2005 10:54 AM
