How To Remove A Technique I Did To My Kithen Walls - Painting - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 06:19 PM   #1
Question
How to remove a technique I did to my kithen walls
Hi
I'm not sure if anyone is familar with this technique - I painted my kitchen walls with a semi gloss interior paint, after the paint dried I used clear glaze and applied tissue paper to the walls. It turned out beautiful I have gotten many compliments about the technique. I did this about 8 - 9 years ago. The paper on the walls are starting to turn yellow. I would like to remove and repaint. Do you know what would be the easiest way I could remove the tissue paper and glaze from my walls? My walls are made of plaster.
Betty Kolp
Richmond MI.
ekolp is offline   Reply With Quote
Old 12-30-2008, 09:23 PM   #2
General Contractor
Was the glaze and acrylic or oil base?
jensenconstruction is offline   Reply With Quote
Old 12-31-2008, 12:14 PM   #3
tissue paper walls- how to remove
The glaze and the paint were both water based - acrylic.
Betty
Old 12-31-2008, 03:54 PM   #4
Rewards Points: 506
That's a toughie. I would apply a coat of Zinsser Gardz to "lock down" that paper. (It is the product to use if you have damaged drywall facing.) Next, skim-coat with Joint Compound to level if you have ANY texture at all to cover. (i.e. seam lines in the paper, wrinkles, etc.) Prime, 2-coats quality paint. (Paint-store products only... no Big Box stuff.)
SirWired
sirwired is offline   Reply With Quote
Old 12-31-2008, 05:54 PM   #5
Rewards Points: 1,520
Have you tried misting it with water, letting it sit, and see if it can be scraped off? Perhaps contact mfg. of the glaze for some advice. Skim coating is not for the novice in my opinion.
bob22 is offline   Reply With Quote
Old 12-31-2008, 05:55 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
SirWired
slickshift is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 10:48 AM
How to remove adhesive from painted walls before painting buffnrie Painting 3 04-27-2008 02:14 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
