How To Remove Stucco Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 04:00 PM   #1
K.M.G's Avatar
Rewards Points: 105
How to Remove stucco ceiling
Hi
I Was watching tv yesterday and saw them spray something on the Ceiling and all the stucco just scraped off.
I want to do the same here and get rid of it,The home was built into 1989
What do I look for at the Hardware store and whats the Best Brand of spray to use.
Also will the Drywall get ruined as it will soak it up
The person that lived here before us smoked bad and the ceiling is "yellow"
It has to go
Thanks for the help
K.M.G is offline   Reply With Quote
Old 08-30-2009, 04:39 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
You are not in California,
Most of the houses out here have Stucco covering the Outside of the house. Stucco is a weatherproof cement plaster, what you have is a Popcorn Ceiling, more properly called an Acoustical ceiling which does not contain cement.
Here are some links:
http://www.google.com/search?aq=0&oq...eiling+removal
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-30-2009, 06:58 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Originally Posted by K.M.G View Post
Hi
It has to go
Thanks for the help
Just plain water will do it if it has not been painted.Soak it and scrape it off
Old 08-30-2009, 07:47 PM   #4
Newbie Bill
Rewards Points: 518
yes, get a spray bottle. put plain water in it. Spray on ceiling. Scrap.
There will be damage to the ceiling from scrapes and things. Specifically where the joints of the drywall were mudded before. Very easy to scrape those a bit. But if you are careful damage should be minimal.
But it is a very messy job.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 08-31-2009, 05:35 AM   #5
chrisn's Avatar
Rewards Points: 122
Now THAT is putting it mildly
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Could there REALLY be asbestos in our ceiling stucco? jenhib Building & Construction 6 08-26-2008 03:33 PM
