How To Remove Paint But Preserve Original Finish? - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 11:25 AM   #1
Question
How to remove paint but preserve original finish?
I have nice solid wood kitchen cabinets that are about 30 yrs old. I really like the door style so no since in changing them out. However they are currently painted white, and they appear to have have been primed before painted. I not only dislike white cabinets...I hate painted cabinets period.
I discovered on the back of one of the cabinet doors had not been painted. The finish is a dark green stain. I would like to remove the paint but maintain the finish.
My concern is removing the original finish with the paint.
I am up for striping the cabinets but not sure What kind of paint stripper to use that will not strip the stain off the original finish. Thanks
Indyguy is offline   Reply With Quote
Old 07-14-2009, 12:37 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Indyguy View Post
......The finish is a dark green stain. I would like to remove the paint but maintain the finish......
When your cabinets were being built, They did not start out being made from wood that had a dark green stain.
After the cabinets, with NO finish, were assembled, then the dark green stain was applied.
Any type of chemical or mechanical stripper is NOT going to be able to differentiate between layers.
Strip the paint and see if you can duplicate the original finish.
To make the messy stripping process easier, some folks take all the doors Off, and take them down to a commercial stripper.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-14-2009, 04:11 PM   #3
diy mike's Avatar
Hate to say it, but any method of stripping is going to remove or damage the finish you're trying to uncover.
I agree with PaliBob - your best bet is to try and match the original finish.
diy mike is offline   Reply With Quote
Old 07-15-2009, 09:52 AM   #4
What about using a heat gun?
Would that preserve the original finish?
Old 07-15-2009, 01:36 PM   #5
diy mike's Avatar
Not even a heat gun is going to do it for you.
Even if you managed to get the paint off without damaging the finish underneath (which would be painstaking and near impossible) you will have some areas where a little stubborn paint clings to the surface. Normally you'd just sand these spots away, but you can't do that without damaging the original finish.
I agree that if you were going to attempt this a heat gun would be the way to go... but the results will not be a clean surface with all the paint stripped and the original finish in pristine condition. Having said that, if you want to give it a shot use a heat gun on one of the doors and see where that gets you. No harm in doing this if you're set on getting rid of the paint.
Sorry for being such a downer, but I don't think this one's possible
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
