How To PREP Plywood For Painting - Painting - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 10:13 PM   #1
Rewards Points: 290
How to PREP Plywood for painting
Have 2 Door Jambs out of 3/4 AC Plywood...
Is there some sorta secret sauce on prepping plywood for painting.
In my only experience with painted plywood (which was a small window header in a bathroom), the paint cracked due to expansion/contraction
mobiledynamics is offline   Reply With Quote
Old 03-30-2012, 11:09 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Plywood door jambs- don't know if I've ever seen that. Is there side grain- layers exposed? Only thing I can think to bridge that kind of thing might be a real thick primer called peel bond.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-30-2012, 11:16 PM   #3
Rewards Points: 290
Actually, fwiw, I have 3 other doors in the same fashion. They may have been skim coated and then painted. They have help up well for 6 plus years.
Ply more stable to boot..
Since I'm doing a full repaint, etc with these new jambs, I want to get things right. I've actually sanded the paint down to bare wood on the existing jambs...
The casings are all exposed - no casing. Modern Detail. Jambs are Baltic Birch.
1/2-1/4" Z Frye Reglet Z Trim - 1 1/2 Jambs.
Old 03-31-2012, 06:18 AM   #4
Too Short? Cut it Again!
If the surface is new, a good old sealer of 1:1 processed (not raw) lindseed oil and mineral spirits would be nice. Ask your paint store for their recommendation for a sealer/primer too though. You want to seal the wood grain so a a primer alone will not do the trick and will haunt you later.
The sequence remains:
Sealer
Primer
Underlay
Finish
Products come with two near components (e.g. sealer/primer or primer/underlay) but sometimes you are best off doing things separately.
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
