-   -   how to paint over old parquet floors (http://www.diychatroom.com/f4/how-paint-over-old-parquet-floors-187124/)
hohadcr 09-17-2013 11:24 AM
Hi, I have several small rooms with 30 year old parquet floors. 1/3 to 1/2 of the floor areas are so worn that the bear wood is showing.
I want to keep the work to the min.
My plan was: to prime the floors with Zinsser BIN. then paint cark or black floor paint / garage paint. And maybe put polyurethane clear finishing.
My question is:
1. of course sending is the best way to ensure bonding. Is Zinsser BIN good enough of a bond for the old floor, considering 1/3 to 1/2 of the floor is already without finishing with the wear?
2. After priming, what is a more durable paint for the indoor rooms? Garage paint? Porch floor paint? Any specific brand?
3. Is it worthwile to add a clear coat of polyurethane after the garage/floor paint to add to the appeal and durability?
Thanks ahead!
Live_Oak 09-17-2013 01:18 PM
Refinishing the parquet isn't an option? Why? It would actually add value to the home to do that, and it's not much more work than all of the work to paint.
hohadcr 09-17-2013 03:53 PM
I did refinish some other old wooden floor that was not as bad as this one. The sanding and refinishing was just too much ... You really think the painting is as bad than the dust and all that from sanding and refinishing?
ddawg16 09-17-2013 04:21 PM
Painting is a very bad idea....besides looking like painted floors, it will not last.
The cost of materials between paint and stain is about the same....
About the only difference in labor is the sanding...you go down and rent a sander with a square sanding pad...takes about half a day...yea, it's messy...that is what a shop vac is for.
The new poly coats are really tough. I did one of the kids rooms about 11 years ago...no signs of wear in the high traffic area (door). The only mistake I made was not being as clean as I should have been...I have a couple of spots with dirt stuck the floor...but you have to look hard to find it.
And if you got the idea to paint off one of those home improvement shows.....stop watching them...they never show the result after a year of use.
cdaniels 09-17-2013 04:27 PM
1 Attachment(s)
Don't do it.I would put vinyl over it if I couldn't refinish it right now.Carpet anything but paint.
chrisn 09-17-2013 05:30 PM
Besides BIn in not made to be walked on, as are most primers:no:
oh'mike 09-17-2013 06:39 PM
Also--you can bet that somebody--sometime in the past,waxed them--so sanding would be needed to ensure a bond---if you are willing to sand,there are some floor paints that might work.
joecaption 09-17-2013 07:14 PM
No way would I ever want a painted floor!!!
Going to be nothing but a mantaince issue from then on.
SeniorSitizen 09-17-2013 08:36 PM
3 Attachment(s)
WAX' WAX you say and more wax ??? :laughing:
Our daughter pulled the carpet in her pre-owned house to replace and found old Parquet. Then it was determined to save it. Our son inlaw was looking for a reason for a new drum sander and was all pumped. He pulled about 900 tiles and we went to work having Parquet Party s. I avoided the removal and install party s :laughing: but boy did I ever enjoy that drum sander. WAX you said. The wife and daughter got real proficient with a random orbit sander, scrapers and block sanders removing wax from joint edges. SIL inspected EVERY piece for WAX residue, rejected a few for a second or third re-run and we were all very pleased with the labor intensive results.
An idea for the OP. Some sheet vinyls are made today that resemble tile so close it's difficult to distinguish from a distance and this may be one of your best options for a DIY project that's not too labor intensive.
hohadcr 09-17-2013 10:38 PM
[QUOTE=Fairview;1243031QUOTE]
Your floor was beautiful.
When we refinished our wooden floor, our varnish got dust stuck in it. The surface is and will always be very scratchy....
How did you kill all the dust?
SeniorSitizen 09-18-2013 09:32 AM
[QUOTE=hohadcr;1243073]
The day before each coat of finish is applied all activity in the house ceases so the dust settles. :wink: The finisher tack cloths the floor, applies finish working back to an entrance and leaves the premises.
ddawg16 09-18-2013 11:24 AM
[QUOTE=Fairview;1243207]
And THAT^^^ was the mistake I made.....I didn't follow up with a tack cloth....I took for grated how clean I as being....you don't leave windows open....
