How To Paint Galvanized? - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 10:26 AM   #1
How to paint galvanized?
I've got some 1 x 2 galvanized corner bead trim in my garage that I need to paint. The top coat I want to use is latex. What is the best way to get the paint to stick? Can I rattle can them with metal etching primer first? Or will latex primer work?
mopowers is offline   Reply With Quote
Old 04-03-2010, 10:38 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Sand them and wipe them down with vinegar or lacquer thinner to get any residual oils off the galvanized. Then use a good acrylic primer and paint. I usually us a DTM on galvanized but regular latex should work fine.
poppameth is offline   Reply With Quote
Old 04-03-2010, 12:24 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Wash them with a mixture of vinegar and water. Then rinse afterward. Then paint as you would any metal. I did that with some galvanized metal 10 years ago and the paint still looks new.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
