How To Paint Drywall After Patching? - Painting - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 08:44 PM   #1
Rewards Points: 682
How to paint drywall after patching?
After using joint compound on drywall, the surface of the drywall area becomes smooth. Upon painting, what techniques can I use to get the drywall texture to "match" the rest of the drywall? I'm not talking about any special drywall texture, just whatever you call the texture that is on the drywall from the lumberyards. Thanks!
kennykenny is offline   Reply With Quote
Old 01-26-2012, 08:55 PM   #2
Gymschu's Avatar
Rewards Points: 1,020
How to blend drywall patches that look too smooth... ?
Recent topic on this very subject. To be honest, you can never get the patched areas to look like the rest of the wall. The best you can hope for is to properly prime them with drywall primer and then repaint.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
jsheridan (01-26-2012), kennykenny (01-26-2012)
Old 01-26-2012, 09:39 PM   #3
Rewards Points: 14,290
Ues Zinzeer 123 primer and two coats of paint.
Old 01-26-2012, 09:51 PM   #4
Rewards Points: 682
Just curious, why this brand vs. others? I use Kilz. Is Zinzeer 123 better quality?
Old 01-26-2012, 09:57 PM   #5
It's like using milk instead of primer.
To thin and not enough stain blockers.
Old 01-27-2012, 07:44 AM   #6
Too Short? Cut it Again!
I only used Kilz in rattle cans for little spot prime things. It is crap.
Old 01-27-2012, 08:43 AM   #7
Sand it smoothe and go over the spots with kilz primer, then prime the entire wall once or twice with a latex primer. If you want to really seal the walls there is another kilz product, I can't remember the name of it, but it's clear, like water, very very thin. It is a sealer and will give you a smoothe finish. If you use this product, use a small roller because it splashes all over the place. It's usually best for damaged drywall, but it will give you a smoothe base to work with, then you prime and paint as usual. It has a 30 minute dry time. If you patched and sanded it right, you won't have to worry about the texture not matching and you won't see the patching.
BTW, IMO, never use kilz in a spray can. There's only about an ounce in the can. The coverage is OK but you won't be able to cover more than a few small spots with a can and once it dries it turns powdery.
BeeTee is offline   Reply With Quote
Old 01-27-2012, 02:39 PM   #8
Learning Things Every Day
Jay 78's Avatar
New, unpainted/unprimed drywall has no texture. The texture you're referring to comes exclusively from the roller nap. The more layers of primer and paint are added to a wall, the more texture buildup there will be.
I refuse to give in and accept that! I'm working on a few techniques. The good thing (or bad, depending on perspective) is that I'm gonna get a lot of practice at my house, and this time I'm taking plenty of before-and-after pictures.
Linking that other thread reminds me I need to make a follow-up post there.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-27-2012, 02:46 PM   #9
Jay 78's Avatar
One other thing....
For the record, it's Zinsser, not Zinzeer. I'm not trying to troll, just saying that people do use the search box, and misspellings won't show up.
Under Construction
The Following User Says Thank You to Jay 78 For This Useful Post:
jsheridan (01-27-2012)
Old 01-27-2012, 05:15 PM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
While we are at it, this statement by beetee is wrong
"If you want to really seal the walls there is another kilz product, I can't remember the name of it, but it's clear, like water, very very thin."
You are thinking of Gardz, NOT a Kilz product but Zinsser
Old 01-27-2012, 08:55 PM   #11
For some people "kilz" is a verb that means to seal something. Also, I think Kilz is comparable to tissue or Kleenex, a generic term for a product.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
