How To Paint A Ceiling Fan - Painting - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 02:28 PM   #1
Rewards Points: 682
How to Paint a Ceiling Fan
I have heard that it is possible to paint over a brass ceiling fan? Has anyone done this and if so, what steps need to be done so it will look good and stick? Does it need to be "roughed" up, primed before painting etc? What are the best ways to cover the areas that you don't want to paint? Thanks!
kennykenny is offline   Reply With Quote
Old 03-16-2008, 08:05 PM   #2
Rewards Points: 506
Yes, you will need to "scuff sand" the parts you want to paint. Some medium-grit sandpaper should do fine. On top of that, use an oil-based bonding primer. (Your paint store should be able to help you with that when you tell them what you are trying to do.)
To block off what you do not want to paint: Tape the edges, and mummify everything else in plastic bags. (Grocery bags work fine.)
SirWired
sirwired is offline   Reply With Quote
Old 03-17-2008, 07:28 PM   #3
Rewards Points: 682
As far as primer, how about the Rust-oleum primerwork for this? Does that kind work on brass? I can't tell if that is the oil based that you were refering to. Thanks for your input.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling Paint CeeZee Painting 12 09-22-2010 12:07 PM
Cement, plaster, paint - ceiling: "spray skim coat"? BradG Painting 1 11-18-2007 06:06 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
