How To Paint 1960's Enamel Fireplace - Painting - DIY Chatroom Home Improvement Forum
Old 12-16-2013, 02:32 PM   #1
How to paint 1960's enamel fireplace
Hi all,
I have an freestanding enamel fireplace (stock internet picture below) made in the 60's or 70's and I'm trying to figure out the best method of painting it. I intend to use this outdoors.
There are two issues I am struggling with:
1) What type of paint should I use. Obviously it should be a high heat paint, but any recommendations on brand and/or type (e.g. engine paint?).
2) How can I ensure a cosistent coat of paint that will adhere well to the fireplace, and at the same time cover the current bright red color. Should it be primed, or lightly sanded. If primed, what type of primer is suitable to high heat?
Thanks for the help. Any ideas would be much appreciated.
tbick is offline   Reply With Quote
Old 12-16-2013, 03:10 PM   #2
Rewards Points: 13,994
I believe your going to find that style fireplace was never intended to be used outside.
Old 12-16-2013, 03:34 PM   #3
I've seen quite a few being used outside. How well they hold up is a different story. I intend to cover it when not in use.
Old 12-16-2013, 04:05 PM   #4
Oso954's Avatar
Rewards Points: 1,320
Engine paint is a poor choice. Most of them are rated for about 500 degrees. There are various stove, grill and BBQ paints with ratings in the 1000-1200 degree range. Rustoleum makes a High Temp Auto Paint that is rated at 2000 degrees.
For priming, sanding, or both, read the instructions on the individual paint can or data sheet.
Most of the high temp paints need to be "cured" at a lower temp (for many the cure is about 50% of rating or less) before they hold up to the higher temps. Many people don't realize this, and complain that the paint failed the first use.
If you really like that stove, you might want to talk to a powder coater about it. They make high temp power coat. Some of the people doing it also do ceramic coatings. You could also ask them about doing the cure job on the paint. A controlled heat would be better than a DIY cure.
I would talk to some locals about the cover. In some areas (like mine), covers can do more harm than good. They can create a sauna effect that exacerbates the rusting, particularly if unvented and/or run all the way to the ground.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Live_Oak (12-18-2013)
Old 12-16-2013, 04:35 PM   #5
Thanks alot Oso954. That's really great information. It does sound like curing properly would be difficult for a DIY, so I'll see if powder coating is in my price range.
Old 12-18-2013, 10:34 AM   #6
K&B Designer
Live_Oak's Avatar
Powder coating is the way to go. Or, just skip trying to fuss with the fireplace and I'll take it off your hands. *cough* cough*
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Tags
enamel paint , outdoor fireplace , preway
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
