How Much Will Primer Hide? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 06:02 AM   #16
Rewards Points: 85
Didn't even know block filler existed til now so I will keep it off the list
joshs is offline   Reply With Quote
The Following User Says Thank You to joshs For This Useful Post:
oh'mike (06-19-2013)
Old 06-19-2013, 06:20 AM   #17
DIY staff
Rewards Points: 7,174
You will be fine---get that primer on and see what you have---remember--shiny paint shows flaws much more that flat or low sheen paints---
Use a flat ceiling paint---and low sheen on the walls---
Old 06-19-2013, 06:44 AM   #18
Rewards Points: 4,796
Call it whatever you want, I'm sure you know what I'm talking about. Some people call block filler a specific masonry product, some use the name more generically.
e.g.
http://www.sherwin-williams.com/home...tion-surfacer/
Up to 11 mils (!) application thickness (i.e. about 10 times thicker than paint).
Use your heads guys, obviously we are not painting our walls with concrete paint where not specified for drywall. Having said that, there are some.
http://www.doitbest.com/Masonry+and+...sku-787523.dib
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
MTN REMODEL LLC (06-19-2013)
Old 06-19-2013, 04:27 PM   #19
An old Tradesmen
Rewards Points: 8,184
Originally Posted by chrisn View Post
not to argue with you( cause it is not worth the effort) but block fillers are for concrete and masonry not drywall
Now you tell me.
Old 06-19-2013, 05:10 PM   #20
Rewards Points: 6,034
e.g.
That is a high build primer not block filler. Block filler is for filling the holes in concrete block is very thick-50 sq.ft to a gallon.
And I don't get how sanding a low spot will come out alright. The more you sand the lower it will get or the bigger the low area will get till you have to do the whole thing over.
Old 06-19-2013, 05:24 PM   #21
DIY staff
This subject has been covered---if the OP returns with more questions--then we can answer them---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
kwikfishron (06-19-2013), TheEplumber (06-19-2013)
Old 06-19-2013, 07:47 PM   #22
Roofmaster
Rewards Points: 2,210
Originally Posted by oh'mike View Post
Drywall taping is a skill only learned with experience---
do not be to rough on yourself---you are the new guy on his first job---look your work over after priming---make the needed touch ups--
This is why the good tapers are always in demand---
Actually, it is best learned from a good professional drywall expert. You can do something wrong for 20 years and you might never learn the mistakes you are making. There is nothing like learning from the best.
Old 06-19-2013, 09:20 PM   #23
I used to work with some guys that used the term for any generic high build coating. But I'm looking around the internet and I don't see anyone using it that way. I guess I will stop using the term block filler except for cinder block, and start saying "high build".
Well technically of course it doesn't come out right. I was just saying that sometimes you can sand surrounding a low spot and you won't notice it when you're done. Doesn't mean it's really the right thing to do.
Old 06-19-2013, 11:00 PM   #24
Rewards Points: 85
Man you guys have a way of taking a question and running with it Thanks again for all the advice!
oh'mike (06-20-2013)
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
What is the best primer to cover and hide wood grain Lulusflowers Painting 8 09-03-2012 05:18 PM
Will primer hide small imperfections in a plaster job? Red Squirrel Drywall & Plaster 3 09-23-2010 10:57 PM
BM Super Hide Primer ? oscarMadison Painting 9 04-20-2009 07:04 PM
Need a good primer to hide paint 'blemishes' DyerWolf Painting 8 03-23-2009 01:49 PM
