How Much Will Primer Hide? - Painting - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 03:27 PM   #1
Rewards Points: 85
how much will primer hide?
Working on final sanding new construction in basement. Pain in the butt ;-)
As I'm going around I have found a fair amount of pock marks and teeny tiny craters in some spots. Will using a 1/2 inch nap and quality primer fill and hide all these little marks?
Or do I need to put another coat on a good portion of my seams?
joshs is offline   Reply With Quote
Old 06-18-2013, 03:30 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
[QUOTE=
?[/QUOTE]
Not really, no.
Jmayspaint is offline   Reply With Quote
Old 06-18-2013, 03:39 PM   #3
Too Short? Cut it Again!
You should take the time to fill and sand them even with the wall. Expecting primer and paint to serve as a filler is asking for trouble. With a wide blade it will go fast and you will have minimal sanding to do unless you goop on the compound. In fact, you can probably wet sand (with car wash sponge) excess from such divots and small imperfections. Than prime and paint.
If you try to Mickey Mouse the surface to start, the defects will end up showing up in your finish coats and especially if you are planning paint within any sheen at all to it. Now is the time to spend the extra effort to get the wall surface the best you can. Otherwise you will be sanding through primer and paint to fix the problem later.
Old 06-18-2013, 03:41 PM   #4
DIY staff
Rewards Points: 7,174
If you think you are done sanding--prime it--then do your spot touch ups---then prime the patches.
Some flaws can't be seen until after priming---that's the nature of drywall taping---
The Following 5 Users Say Thank You to oh'mike For This Useful Post:
Brushjockey (06-18-2013), chrisn (06-18-2013), Gymschu (06-18-2013), Jmayspaint (06-18-2013), user1007 (06-18-2013)
Old 06-18-2013, 03:50 PM   #5
Rewards Points: 85
Thanks for the replies. Just sick of sanding :-)
Old 06-18-2013, 04:13 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,830
Josh.... Just remember... sanding is for high spots.... filling is for low spots. (I know sounds stupid... but sometimes we're reluctant to open the mud bucket again... ans somehow think we can sand out low spots.)
MTN REMODEL LLC is online now   Reply With Quote
Old 06-18-2013, 04:37 PM   #7
I have gotten to the same point so many times over the years but realize you are near the end. You will kick yourself if you have come this far and try to compromise now.
Old 06-18-2013, 04:40 PM   #8
Yes... Or go real heavy knockdown....
Old 06-18-2013, 04:50 PM   #9
DIY staff
Drywall taping is a skill only learned with experience---
do not be to rough on yourself---you are the new guy on his first job---look your work over after priming---make the needed touch ups--
This is why the good tapers are always in demand---
MTN REMODEL LLC (06-18-2013)
Old 06-18-2013, 07:23 PM   #10
Rewards Points: 4,796
There are primers called block fillers that will fill those in. But really it's easier to just fill them in.
jeffnc is offline   Reply With Quote
Old 06-18-2013, 07:24 PM   #11
Yeah, well the problem is, sometimes you can sand out the low spots, and sometimes it works. That's the reason it's tempting to try
Old 06-18-2013, 07:38 PM   #12
Painting Contractor CT
Rewards Points: 77
Post
Apply a coat of primer first, then try to fix any imperfections that there may be.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-18-2013, 07:44 PM   #13
Jeff.... I know and agree with you... that's why I'm the world's slowest finisher.
Best
Old 06-19-2013, 03:30 AM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
not to argue with you( cause it is not worth the effort) but block fillers are for concrete and masonry not drywall
The Following 2 Users Say Thank You to chrisn For This Useful Post:
oh'mike (06-19-2013), ToolSeeker (06-19-2013)
Old 06-19-2013, 05:57 AM   #15
DIY staff
What ever you do--do not use block filler---
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
What is the best primer to cover and hide wood grain Lulusflowers Painting 8 09-03-2012 05:18 PM
Will primer hide small imperfections in a plaster job? Red Squirrel Drywall & Plaster 3 09-23-2010 10:57 PM
BM Super Hide Primer ? oscarMadison Painting 9 04-20-2009 07:04 PM
Need a good primer to hide paint 'blemishes' DyerWolf Painting 8 03-23-2009 01:49 PM
