How Much Paint Do I Need? - Painting - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 08:32 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
How much paint do I need?
I am planning on painting a small powder room, that is approx. 7 feet by 4 feet.
There is a window and a door and a strip of vertical tiling approx. 2 feet by 9 feet. (9foot ceilings)
The reason I am asking is if I can get away with purchasing one of those small little containers of paint.
Thanks ya'll
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 02-02-2013, 08:43 PM   #2
Rewards Points: 13,270
Not going to happen.
Buy the gal.
Old 02-02-2013, 08:53 PM   #3
Rewards Points: 558
Your better off buying the gallon for future reference look at this site to estimate the gallons of paint required
http://www.dummies.com/how-to/conten...nt-to-buy.html
epson is offline   Reply With Quote
Old 02-02-2013, 09:03 PM   #4
cdaniels's Avatar
A gallon would be enough for two good coats. A quart would do the door and window.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-02-2013, 09:09 PM   #5
Ok, I guess it's a gallon.
I just didn't want to buy that much if I didn't need to, as I will be painting it a dark colour and I don't think I would have any use for the rest of it.
Thanks very much for your help.
Old 02-02-2013, 09:19 PM   #6
The temptation to buy a quart is strong, but everybody's right. Considering a quart covers 100 sq ft, or less, minus what gets absorbed into the roller that you don't get back, a quart doesn't cut it. You'll use even more if your first coat goes over a flat.
BTW, when you say a dark color, how dark, and what brand are you buying? Some dark colors require more than two coats.
Old 02-02-2013, 09:22 PM   #7
I just measured and I have 108 square feet of wall space to be painted.
There is a fairly large window for such a small bathroom, and a door on one wall.
Can I get away with a small container doing three coats......lol
Old 02-02-2013, 09:24 PM   #8
Thanks jsheridan.
The colour I plan on using is dark brown, and I plan on using Benjamin Moore.
I just know I probably won't be using the rest of it.
Old 02-02-2013, 09:48 PM   #9
That's 108 sq ft per coat. whether that's gross or net, you're still over a quart. Be sure you get a product that uses the Genex tints, which have the superior hiding properties, although browns usually cover pretty well.
Old 02-02-2013, 09:59 PM   #10
Thanks so much jsheridan.
I will go with the gallon, I guess.
Old 02-02-2013, 10:10 PM   #11
I still argue with myself over quart versus gallon, in spite of all the hard lessons I learned early on. Not so much for the cost, but because of the leftover going to waste. My mother was born at the end of the Depression, and my grandmother was seriously influenced by it. So I grew up in a Depression Baby household, and it's still with me. I still add a little water to get the last of the ketchup out of the bottle, and I don't throw soap ends away either.
I'm starting to sound like Sdsester. BTW, has he been seen lately?
Old 02-02-2013, 10:20 PM   #12
Gymschu's Avatar
Rewards Points: 466
Over the years I have tried the "buy the quart, not the gallon" route to painting a small area.........about 99.9% of the time, I ran out of paint and had to buy another quart. As most painters know, a quart can cost about as much as a gallon so you end up spending MORE than you would have if you just buy the gallon.........not to mention that the new quart doesn't quite match the first quart in color.......anyway, you get the picture, buy the gallon and you buy piece of mind.
The Following User Says Thank You to Gymschu For This Useful Post:
jsheridan (02-02-2013)
Old 02-02-2013, 10:50 PM   #13
SD hasn't been around since 12/9/12.
Old 02-03-2013, 06:06 AM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
He left, permently, so he said. Got really pissed at somebody and said , no more.
Old 02-03-2013, 07:34 AM   #15
That sucks, he added a lot of color to the forum. Maybe they finally got his meds right and he came to his senses.
I contacted him through his personal site, if he doesn't respond it may have been me. I'll miss him.
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
