Old 11-01-2006, 12:37 PM   #1
Question
How much do professional painters charge...
To prime and paint a bedroom that is approx 12x12? I need the room repainted professionally and I'm in Pinellas County, Florida...Angeline
AngelineK is offline   Reply With Quote
Old 11-01-2006, 12:40 PM   #2
Paperhanger/painter
ProWallGuy's Avatar
It all depends......
Call 3 paint contractors in your area and find out.
Try using the PDCA website to find a local paint contractor.
Plus, you don't give near enough info.
Does the ceiling get painted?
Trim, doors, windows, base, crown, etc.?
What condition are the walls in?
Color change?
Prep/patching to be done?
Lot of furniture to move?
Etc etc etc
ProWallGuy
ProWallGuy is offline   Reply With Quote
Old 11-01-2006, 12:50 PM   #3
The color needs to be changed...
The walls are in good condition...furniture does not need to be moved...ceilings are fine...no worry about doors etc.
just basically prime and paint...
Old 11-01-2006, 05:28 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
The labor is the biggest part, and that can vary greatly in different parts of the country
Best way to determine the going rate for your area is:
You can disregard any real high or real low bids, and get a general idea
slickshift is offline   Reply With Quote
Old 11-06-2006, 08:35 PM   #5
Central Florida Painter
YourWayPainting's Avatar
Make sure that any painter you hire is licensed and insured. A good painter will also insist on using quality materials. There are too many painters that "blow and go" out there. Check references once you have a couple of bids that you like.
Prices vary widely ... and will depend on the colors you select also (reds are always extra for me).
Get some free estimates and go from there.
A good paint job isn't cheap. A cheap paint job isn't good.
YourWayPainting is offline   Reply With Quote
Old 11-06-2006, 11:51 PM   #6
747
registered
747's Avatar
325.00 including the ceiling. Thats what i say. Just call around and ask how much they charge per square foot. You have 144 square feet. If they charge 2.00 a square mulitiply that by 144 which would be 288.00 example.
747 is offline   Reply With Quote
Doors - How much to charge? lmark5 Painting 7 07-29-2007 01:45 AM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
painting over spots created by painters putty azalee Painting 4 04-05-2007 11:56 AM
How much do I charge? canadaclub General Discussion 3 11-09-2006 07:04 PM
Consumer Reports vs painters' opinion on exterior paints popkadurak Painting 2 06-15-2006 07:16 AM
