How Many Coats Of Primer Do I Need On Fresh Drywall? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-06-2009, 07:55 PM   #31
So I went to SW tonight, and told them about my basement project and rather than a primer, they said I should use tinted CHB as it will offer best coverage. This seemed a bit odd to me, but I went on their recommendation as I figured they were the experts. We'll see how it works.
ThunderCAT is offline   Reply With Quote
Old 05-07-2009, 05:54 AM   #32
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
tinted CHB?
chrisn is online now   Reply With Quote
Old 05-07-2009, 09:57 AM   #33
Well, maybe tinted is the wrong term since CHB is a latex paint. I guess it's just a mixed color that's close to what we think our final color will be. We were deciding (and still are deciding) between a couple of options that are very close in color, so they gave us a lighter version of one of the colors to use as a base coat.
Old 05-08-2009, 05:26 AM   #34
chrisn's Avatar
Rewards Points: 124
what is CHB?
Old 05-08-2009, 10:39 AM   #35
CHB is model of latex paint from Sherwin Williams. It sure covered good on the first coat.
Old 05-08-2009, 11:20 AM   #36
Matthewt1970's Avatar
Rewards Points: 1,098
So instead of a primer, Sherwin Williams recommended one of thier lower end Latex Paints for a first coat on new drywall........Ok....
Old 05-08-2009, 01:47 PM   #37
I know, I asked them essentially the same thing and was assured this would work just as good with better coverage.
Old 05-08-2009, 01:50 PM   #38
Rewards Points: 506
Well, I don't know about CHB in particular, but I do know that their "Builder's Solution" and ProTouch Flat paints are designed to be primerless and hide well. I can't say I would use them as a final topcoat I wanted to last, but I could see the clerk recommending them instead of primer on new drywall.
SirWired
sirwired is offline   Reply With Quote
Old 05-08-2009, 02:57 PM   #39
SirWired
We won't be using this paint as our final coat - just the base coat. I've been doing a bit of reading, and have found a couple other places that claim CHB works great as a "primer" for new drywall. Hope it works out!
Old 05-09-2009, 12:10 AM   #40
Will it work? Sure. Will it seal and give you the same durability a true primer would? Not hardly. Now add higher levels of humidity being in a basement....
Old 07-05-2009, 01:51 PM   #41
hi,
i just finished hanging, taping, and mudding, my first drywall project. got the sanding done, looks pretty good. now the painting. i am planning on purchasing glidden pva, for under latex primer. is this a good choice???...bob
bobo60 is offline   Reply With Quote
Old 07-05-2009, 01:54 PM   #42
yummy mummy's Avatar
Rewards Points: 1,016
I used CIL acrylic drywall primer, and it worked good for me.
I then put on 2 coats of Benjamin Moore paint, and it look good.
I love BM paint. I have never painted before, and really like the way BM covers.
Good luck.
yummy mummy is offline   Reply With Quote
Old 07-05-2009, 02:38 PM   #43
Originally Posted by bobo60 View Post
hi,
Stay away from anything with the word "Glidden" on it. Go to a Sherwin Williams and get PrepRite Classic (not the 400) or go to Benjamin Moore and get Fresh Start for primer. Either can be tinted to match your finish color and either will seal, bond, and give you a great surface for your finish coat.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 01:27 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
