-   -   How many coats of primer do I need on fresh drywall? (http://www.diychatroom.com/f4/how-many-coats-primer-do-i-need-fresh-drywall-36501/)
yummy mummy 01-21-2009 03:14 PM
Is one coat enough or do I need to do two.
USP45 01-21-2009 03:20 PM
One. But do yourself a favor, use a good quality primer. I found that Valspar is good. If you think its expensive, you are right, but it only requires a one coat cover where the 1/2 priced primers require 2 to 3 coats.
You do the math!
yummy mummy 01-21-2009 03:24 PM
Thanks for the info.
I wonder if we in Canada carry that brand?
I have done one coat on my textured ceiling and I used CIL acrylic latex drywall primer from HD. I think it cost about $28.
I don't mind spending the extra money, as long as I get a good end result.
Thanks again.
USP45 01-21-2009 03:27 PM
Any name brand will do, Valspar, Duron, Benjimen More, Dupont and so on. Try to stay away from those 20 dollar a gallon deals at WalMart though.
yummy mummy 01-21-2009 03:29 PM
I will definitely stay away from WalMart.................lol
Bob Mariani 01-21-2009 04:44 PM
One coat. It will look like it did not cover well, but do not worry about this. It is normal. IT seals, the top coats cover.
what you need is a PVA primer.. it is used for new drywall. Or a paint marked Seal and Block. Any other primer is not really for new drywall.
slickshift 01-21-2009 05:04 PM
*One*
yummy mummy 01-22-2009 08:54 AM
Thanks Bob.
I just went to read the one that I have used and it says it has good sealing and hiding properties.
I sure could use the hiding...............:laughing:
sirwired 01-22-2009 11:27 AM
You actually don't need any hide... that is meant for say, a dark green -> daffodill yellow color transition.
Oh, and Friends Don't Let Friends Use Kilz2. Just stay away, no matter what the can says.
SirWired
747 01-22-2009 12:42 PM
zinsser bulleye 123 interior exterior primer sealer. HD should have it. Not that expensive. Last time i bought it 10 dollars a gallon. It was on sale.
One coat your good to go. Might want to hit walls after dried lightly with some fine grade sandpaper or just a light sweep with a drywallers screen.
yummy mummy 01-22-2009 04:50 PM
SirWired
I thought by hiding they meant hiding very small imperfections in my mudding..................?
yummy mummy 01-22-2009 04:51 PM
What is kilz2?
jaros bros. 01-22-2009 06:08 PM
Just because it is just this brand or that does not make a primer or paint good. Just about every company makes good paint. They will usually sell three to 6 different grades of their paint. Price is almost a 100% guarantee of the quality. Don't think you are getting good paint or primer if your are only paying $20 a gallon and it is any brand.
Josh Jaros
DangerMouse 01-22-2009 06:42 PM
my friend just asked what happens if you don't use primer and just paint on the drywall?
says he did it in his bedroom 7 years ago and it looks fine, so why he asks?
DM
sirwired 01-22-2009 06:52 PM
"Hide" refers to how opaque it is, and high-hide primer is used for extremely drastic color changes. Hiding defects in your finish would be accomplished by a "high-build" primer, but those are usually only used when painting brick and cinderblock.
If your mudding is not smooth, you can sand (and vacuum) it prior to priming.
SirWired
