How Many Coats Of Primer Do I Need - Painting - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 01:38 PM   #1
how many coats of primer do i need
i painted 2 walls in my apt "periwinkle" purple, i have recentley moved out, and my landlord is trying to say it has taken 10 gallons of primer to cover 2 8x12 walls! of course she is trying to keep my deposit.
tammisu is offline   Reply With Quote
Old 03-26-2012, 01:53 PM   #2
Rewards Points: 256
What was the agreement between you and the landlord before you painted the wall?
michaelcherr is offline   Reply With Quote
Old 03-26-2012, 02:02 PM   #3
Rewards Points: 384
Hiya Tammi...
Of course she keeping your deposit. And if it wasn't the paint, it'd most likely be something else - but if her only complaint is she had to repaint the walls, 10 gallon would be enough to apply approximately 15 coats of primer (that must've been one really dark periwinkle). That is figuring 300 square feet per gallon, which is very much attainable over a painted surface.
Good luck with your deposit, but I wouldn't write any checks against it's return though.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
Gymschu (03-27-2012)
Old 03-26-2012, 02:13 PM   #4
Just a DIY guy
I just primered my guest bath, and it has the same square footage as your walls. (mine=190, yours=192)
I did two coats as it was a b!tch to cover the new spray texture completely. It took only one gallon.
M3 Pete is offline   Reply With Quote
Old 03-26-2012, 02:31 PM   #5
Rewards Points: 256
It seems like your landlord clearly lied about paint consumption. I don't know why the landlord lied, he/she would have been very justified in keeping your deposit without fabricating info.
I am a landlord, I would have gotten a quote from a professional (very expensive) painter, and submitted a copy to you, anything left over (which there likely wouldn't be) would be refunded. Unless your lease forbid painting without prior approval (which mine does), in which case there would be a fine on top of it.
2 coats stain or 1 coat primer & 1 coat paint? bhtko Painting 25 08-11-2012 07:43 PM
Amount of coats of primer and paint humberguy Painting 3 11-28-2009 11:20 AM
How many coats of primer do I need on fresh drywall? yummy mummy Painting 42 07-05-2009 02:38 PM
painting dark from light, how many primer coats? Miss Molly Painting 6 05-20-2009 11:04 AM
Primer how many coats? kimbur96 Painting 8 10-19-2008 08:28 AM
