How Long To Wait After Painting To Rehang A Door? - Painting - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 12:23 PM   #1
Rav
Rewards Points: 552
How long to wait after painting to rehang a door?
I've just completed painting a wood panel door (both sides, edges, and the door frame). I cleaned, sanded, repaired, primed with X-I-M UMA, and applied two coats of Duron Signature Select interior acrylic latex semi-gloss. Duron's web site says this paint has "superior block resistance." How long should I wait to rehang the door, to avoid any sticking issues? Thanks.
Rav is offline   Reply With Quote
Old 08-07-2012, 12:47 PM   #2
Rewards Points: 13,270
24 hours if you can wait that long.
Old 08-07-2012, 09:10 PM   #3
Rav
Rewards Points: 552
OK, thanks Joe. I can and I will.
Old 08-07-2012, 09:12 PM   #4
ARC Painting's Avatar
24 hours in a relatively dry environment. I've seen issues in high humidity where it took longer, but its rarely a problem.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 08-09-2012, 07:44 AM   #5
Too Short? Cut it Again!
Just remember semi-gloss, even though surface dry in hours, takes 30 days to fully cure. Be careful not to ding up your nice new surface when it is still soft under the skinned layer.
The Following User Says Thank You to user1007 For This Useful Post:
Faron79 (08-09-2012)
How long to wait before troweling concrete step face? czissman Concrete, Stone & Masonry 7 03-09-2012 03:48 PM
exterior front door painting after builder paint m1951mm Painting 9 08-20-2011 09:20 PM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Painting door frames hockeymom Painting 5 09-07-2009 05:04 AM
Painting an exteior "fiberglass" glossy new door from Lowe's madducks Painting 2 06-21-2009 12:11 PM
