How Long Should I Wait To Prime Siding After Pressure Washing? - Painting - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 08:44 PM   #1
Rewards Points: 260
How long should I wait to prime siding after pressure washing?
I am pressure washing my rough sawn plywood siding. How long should I wait before I start the painting procedures? I want to make sure the wood is dry, so I don't get blistering or bubbling down the road.
bluefitness is offline   Reply With Quote
Old 02-08-2009, 09:15 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
ah till its dry?
Tom Struble is offline   Reply With Quote
Old 02-09-2009, 06:35 AM   #3
Remodeling Contractor
Yep! that nails it
Old 02-09-2009, 06:26 PM   #4
Rewards Points: 260
It looks and feels dry after a couple of hours. It has some cracking, so I'm worried about moisture issues. I thought it was supposed to take at least a day.
Old 02-09-2009, 06:28 PM   #5
what paint are you using? Stain I hope?
Old 02-09-2009, 06:44 PM   #6
Rewards Points: 260
I am going to use a SW line paint. I'm not sure just yet. The house has primer plus one coat on some areas and two to three coats of paint in others. The siding has been changed sporadically.
Old 02-12-2009, 05:54 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
3 days is the "rule"
However, if it's in real sun for a day it could be just fine
And, cloudy, damp, temp-changing, days it could be more
slickshift is offline   Reply With Quote
Old 02-12-2009, 06:42 PM   #8
only way to know if it is dry enough is to test with a moisture meter. Look for 5%
Old 02-12-2009, 10:37 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
We would typicly power wash a house one day and be back as soon as the next morning scraping. If it's too wet to prime you will know right off the bat.
how long to let pressure treated wood dry before painting? vendejp Painting 18 08-08-2012 08:53 PM
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 11:51 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
