How Long To Let Pressure Treated Wood Dry Before Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 11-01-2007, 10:06 AM   #1
how long to let pressure treated wood dry before painting?
This is obviously an exterior application. Is there a rule of thumb, or just till you think the wood feels dried out?
Thanks in advance
vendejp is offline   Reply With Quote
Old 11-01-2007, 11:39 AM   #2
Guest
Guest
Posts: n/a
Safest thing to do is test it with a moisture meter.
Old 11-01-2007, 03:35 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks in advance
It is dependant on the weather, the region, condition of the wood, opinion, etc..
Read up:
http://www.taunton.com/finehomebuild...ood-decks.aspx:
"Most water repellents can be applied immediately to the new pressure-treated wood, and some manufacturers offer a water-repellent treatment as an upgrade. But manufacturers still recommend an additional level of protection. The wood preservers group suggests waiting for the lumber to dry before applying an oil-based semitransparent stain to the new varieties of pressure-treated lumber. How long you should wait before applying the stain varies depending on where you live. In New Mexico, you probably should wait for six weeks; in New Orleans, six months would be a more preferable length of time."
http://www.messmers.com/prod_up_faq.html:
"Q: How long should I let my deck weather before applying UV Plus for Pressure Treated Wood? A: New pressure treated lumber should weather six to eight weeks minimum before applying UV Plus for Pressure Treated Wood. The wood needs to weather sufficiently to allow the pores to open up to accept the stain. Failure to do so will cause premature failure and possible surface sheen problems."
http://www.wikihow.com/Seal-and-Stai...d-Wood-Decking:
"On new decks, it is better to let the wood weather for about a year before applying a new finish. This lets some of the chemicals escape from the treated lumber and lets the grain open up, so the new finish penetrates better."
- Build Well -
Old 11-01-2007, 04:53 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Although some pressure treated wood suppliers will tell you you can paint immediately, I have seen that lead to coating failure
I've never seen or heard of PT wood that's been "seasoned" for a season (3 months) or longer have a problem
slickshift is offline   Reply With Quote
Old 11-02-2007, 11:12 AM   #5
Guest
Guest
Posts: n/a
Sikkens says 6 weeks but I don't trust that either. We usually recommend 6 months to be safe 3 at a minimum.
Old 11-02-2007, 02:27 PM   #6
Let dry and do this...
Do a moisture test on the lumber. My brother has one the largest hardwood floor companies in the Greenbay Wi. area. He tests before finishing his floors. If it is dry it is dry.....ya think!!!!! If you live in the Amazon where it rains everyday....probably won't be able to ever seal it.....suggest you contact the manufacture direct if you really need the answer. I'm going with a couple of months at the most. You probably will be power washing it and sealing it again soon anyway. One coat every couple of years will really make it last. Would you put one coat of paint on your walls in your house and call it good. I never have call backs on anything. Very RARE..... Better safe than sorry. It's kinda like when the manufactures put out the siding that was suppose to last a life time. The old aluminum siding that looks pretty bad right now around the U.S.A. that everyone is painting or replaceing. MY MOTO........Build perfect!!!
localtradesman is offline   Reply With Quote
Old 05-19-2009, 08:49 AM   #7
Moisture
Amen, brother! I built a picket fence in my front yard. Halfway through, Southern Livig comes out and wants to do a photo shoot for the magazine. Cool! The problem is they wanted to do the shoot while thier photographer was in town and could I have it like, speedy done and painted in a week. Well, Hell YES!
Its a cool fence 1x1 sandwiched between 1x3 rails held up by 6x6 post all AQC. I was drentched cutting points on all the 100s of 1x1. Very wet stuff. A coal of Kills and high Gloss black for that wrought iron look.
Photo shoot went off with out a hitch.
6 years later, I can not keep paint on the fence. Peels with in a season.
Blisters with in a few hours with fresh paint.
My only solution is to pressure wash the entire fence. Let it try to dry a summer season in The Deep South, and pray paint will stick.
I jusdt finished a surperb Privacy fence and came here looking for drying answers........I'm gonna wait 1.5 months to Black stain this one. Home Depot off the shelf wood!
RatFink is offline   Reply With Quote
Old 05-19-2009, 09:53 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
Pressure treated wood should really be stained rather than painted. 3 Months is the bare minimum to wait.
Old 05-20-2009, 10:24 AM   #9
Absolutly stain! It soakes right in. Some times too much.LOL
It realy saves the wood grain look and easy to apply .Thinning is a breez. A standard wagner sprayer does a bang up job.
Still gonna let the fench dry 6 weeks b/4 the aplication. I'll post a few photos for fun since this is sort of a slow thread!
Old 05-25-2009, 09:46 AM   #10
The Cabot Woodcare Co told me to wait 30 days, then to apply a very thin coat of oil based decking stain, only to use a brush & apply just one coat If you go to their website (cabotstain.com) you get some pretty good info.
Dennis
djtjak43 is offline   Reply With Quote
Old 05-25-2009, 12:11 PM   #11
Unless your wood has the Kiln date on it, I highly suggest you let the wood dry for 3 months. Even if it has the date, keep in mind it was probably stacked somewhere without proper drying ventilation.
Old 05-25-2009, 01:07 PM   #12
Cabots and Lowes
I've used the stain on cedar and with wonderful sucess.
If I may toot my horn. If anyone wants to go look in the Lowes Creative Ideas Magazine for May, there is a Tiki Bar that I built. The stain is on the cedar planks and realy turned out to be a nice work project. Took about 2 months and $12K, not the two weeks and $7K they wrote!
Thanks for the tip. I'm going for the 2 months, but raining every day about down here in Birmingham.
Dennis
Old 05-28-2009, 02:13 PM   #13
Originally Posted by fast1 View Post
wow 12k... isn't that expensive?
I take it you haven't seen the article.
Plumbing from hell had to tie it below the deck and through the two story footings. Electrical and hot and cold water supply wasn't just free. Its never as simple as it looks.
Rained 10 days the last two weeks on my new fence. I juess its drying. The sun comes out bright and you can see the steam raisin g off the top.
Old 05-28-2009, 02:38 PM   #14
most people go get it to put up now & i'll bet lows/home or who ever test the treated wood the moisture will be high & no - way ready to use. lumber companys push it. let it dry & in my home town it's over 100 for months & I'll waite 6 months & then it looks 50 years old
huffanpuff is offline   Reply With Quote
Old 05-28-2009, 07:38 PM   #15
New Mexico!!!
Now thats Hot and low humidity. I've been in the habit of replacing our deck on Dauphin Island, Alabama every7 years. Brother you know HOT.Pressure treated wood dries out with in a week in these conditions.
I've seen stain poured into week old wood like water into a sponge, not to mention wasting water seal. We just budget it in to rip out the deck system every 7 years if mother nature doesn't pick it up and remove it for us.
Lowes/HD is no exception. I've ordered bulk loads of green wood direct from the lumber yard and had it right out of the kilm and still soaking. At least the big box yards have the time in shipment to get a few weeks of drying. I've come to the realisation that stain is the only way to go. Its cheap compared to the over all cost of material and labor to build a quality fence, or what ever outside.Just gonna keep soaking in the stain and aviod paint all together.
uote=huffanpuff;279794]most people go get it to put up now & i'll bet lows/home or who ever test the treated wood the moisture will be high & no - way ready to use. lumber companys push it. let it dry & in my home town it's over 100 for months & I'll waite 6 months & then it looks 50 years old[/quote]
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 08:43 AM
Painting pressure treated wood Crackers Building & Construction 1 08-27-2007 10:51 AM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-06-2007 11:23 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 09:04 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 12:38 PM
