How Long Does Pva Primer Last In Can? - Painting - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 07:56 PM   #1
How long does pva primer last in can?
About to prime some gyp bd and found a 5 gal pail of pva primer but its 5 yrs old. Should I toss it and buy new? Or if if it looks and smells ok its good to go? Thanks for all your advice.
dfrey is offline   Reply With Quote
Old 08-18-2012, 09:51 PM   #2
Rewards Points: 386
There are more factors than just age that will determine whether this paint is still viable, but if it can be mixed into a uniform consistency - and still has a fresh smell (not sour or musty), it's probably OK. If you're still unsure, take it back to where it came from - or take it to your local paint dealer - for their opinion.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
Will22 (08-22-2012)
Old 08-18-2012, 09:58 PM   #3
Rewards Points: 582
what will be the cost to you if it does not work....after 5yrs good chance its bad... whats the cost of just buying new primer....?????just my 2 cents..
Old 08-18-2012, 11:04 PM   #4
Paint Pro
take it to a paint store, have them shake it up for you and tell you if its good or bad. (take it to the same store where it was originally bought if possible). the guys at sherwin and benmoore in my area will shake up anything for you, but i have came across some people who dont appreciate being asked to shake a competitors old paint
Expert Paint is offline   Reply With Quote
Old 08-19-2012, 05:10 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 510
If it was me, I would toss it and buy some good primer, pva is not it, IMO
The Following 2 Users Say Thank You to chrisn For This Useful Post:
ben's plumbing (08-19-2012), user1007 (08-19-2012)
Old 08-19-2012, 05:42 AM   #6
Too Short? Cut it Again!
Whether it is still alright will depend on so many factors like how much was in the bucket when it was sealed up and how much in there is air space? Did you lay some saran wrap on the surface to keep it from skinning? Was it subjected to temperature extremes? Did you return unused paint from a paint tray to it that might have picked up particulates or even organics to it that have had five years to react?
If you find you can and want to use it, I would definitely plan on straining it through some cheesecloth or those inexpensive strainers before use so you are not tripping over "gloppy dos" and fragments that have fallen from the top or sides into the paint. Nothing more frustrating other than having to pull them from your primed surface as the roller scatters them. Almost as much fun as picking cheap paint brush bristles from a surface.
I agree that I would be inclined to buy new material it at all in doubt.
Paint is so much like fine wine. You should decant leftovers to containers with the least amount of airspace when you are done painting. Keep some empty cleaned out gallon and quart containers on hand for this. And of course, try not to buy more than you need but for touch ups.
Old 08-19-2012, 11:06 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
'This x2.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
How long a wait before primer? paintboy Painting 2 10-03-2011 07:05 PM
PVA Primer Disaster bobcatm Painting 1 08-17-2010 12:41 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 06:29 AM
Thoughts on using Exterior SW Duration as a primer. refreshrate Painting 7 06-09-2009 09:40 AM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 04:32 PM
