#1 |
How long does paint last in can
I will be painting a bathroom vanity and found some primer in my storage room that has been opened, but sealed up well. I'm not sure how old it is, but it may be as old as 4 years. Can I still use it for my project?
#2 |
That's a tough call Ratso, especially without knowing what primer it is. It's an on the spot judgment call. I would tell you no off the top of my head. I can tell you that if it's bad, and say never dries properly, it's going to cost you a lot more than the 10 buck cost of a new quart to fix.
A vanity should get a coat of bonding primer. Go to Home Depot, or the local hardware, and get a quart of Zinsser 123 latex primer. Better to be safe than sorry.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following 3 Users Say Thank You to jsheridan For This Useful Post: |
#3 |
Why take the chance?
#4 |
Average Joe/ex-Navy IC3
4 years in storage, go get some new paint.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| The Following User Says Thank You to gregzoll For This Useful Post: | ltd (01-13-2013) |
#5 |
4 years isn't that long assuming it was stored where it didn't freeze or get too hot and the container was sealed up good.
I've used paint and primer older than that (much older). |
#6 |
I have had paint last 10 years and still be good and I have seen it go bad in as quick as 2.
Latex Primer: Good for Drywall, that's about it. Behr Paint: The plastic buckets are good, that's about it. |
#7 | |
How long does paint last in canQuote:
| The Following User Says Thank You to jsheridan For This Useful Post: | ToolSeeker (01-14-2013) |
#8 |
Rubbin walls since'79
JS- everything working? (nothing to do with thread btw..)
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#9 |
Not yet. Sent you a pm.
#10 |
Paints and primers (especially with the low-VOC technology and content at present time) do not have the same freeze/thaw resistance as the products in the past. The general label storage directive is one year minimum, unopened, where it used to be probably 2-3 years. It depends upon how the can was resealed, and where it was stored. Stir it up, make certain that it smells OK. Solvent products can be tricky, although latex/waterborne paints are pretty obvious.
#11 |
I have had paints last 20 years- others went bad in 6 mo.
Open up and stir- the smell test is a good one,if it is funky- don't use. And if it is like cottage cheese- it froze. And floating green/black stuff is not a good sign...
| Display Modes | |
| Cleaning brush | StevenH | Painting | 19 | 02-06-2011 12:13 AM |
| long lasting glow in the dark paint | TJSXOX | Painting | 7 | 09-17-2010 09:19 AM |
| semi gloss enamel vs eggshell enamel | NoExperience | Painting | 18 | 03-05-2009 05:57 AM |
| So many questions where to start?!?!(NEWBIE) | painter84 | Painting | 5 | 09-15-2008 01:50 PM |
| Paint recommendations and finish questions | EJacobs | Painting | 2 | 09-03-2008 11:38 PM |
