How Long Do I Have To Wait Before Putting Tape On Fresh Painted Wall - Painting - DIY Chatroom Home Improvement Forum
Old 08-28-2009, 04:00 PM   #1
New Home Owner
How long do I have to wait before putting tape on fresh painted wall
Just painted the walls with Benjamin Moore Collections paint. Im no pro so I used tape on the trim.
Now I need to put tape on the wall so I can paint the trim. How long do I have to let the paint cure before the Green 3M tape wont pull any paint off.
Anyone know.
Thanks a lot
Brandon19 is offline   Reply With Quote
Old 08-28-2009, 04:09 PM   #2
Haste Makes Waste
30 days for the paint to cure before applying tape. Remove tape about 15-20 minutes after painting. If the paint dries, you'll have a paint edge.
When removing the tape, be VERY careful not to peel the paint.
I have used tape on painted walls about a week later and had a few small peel problems that I just corrected with more paint, but that is not really the preferred way.
saggdevil is offline   Reply With Quote
Old 08-28-2009, 07:53 PM   #3
Rewards Points: 41
I just painted trim and molding without taping anything except the floor. I used a good angled brush and a metal edge guide, plus damp paper towels to wipe off any dribbles (this assumes you are using latex).
The process was much easier and faster than taping.
Amycat is offline   Reply With Quote
Old 08-28-2009, 09:20 PM   #4
Haste Makes Waste
yes it is and i can get away with that in some areas, but i have 1913 original woodwork and can't afford to mess it up, lol.
Old 08-29-2009, 12:25 AM   #5
Painting Contractor
if you must tape your walls, pick up some delicate blue tape from 3m. it has an orange core and will not pull the paint from your freshly painted walls, even if applied the next day. We have used this before with excellent results. You can generally find this at your local paint stores, sherwin williams etc
Mantis is offline   Reply With Quote
Old 08-29-2009, 05:13 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
chrisn is online now   Reply With Quote
Old 08-29-2009, 08:23 AM   #7
Remodeling Contractor
the new frog green tape works better than that blue tape. You can tape over the painted edge about 3 hours latter. Do this all the time for making strips or designs. Read more on painting over taped edges.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
How long can I wait before putting up the drywall without warping the wood framing? atm Drywall & Plaster 9 05-01-2009 09:07 AM
Putting a hole in a wall without getting electrocuted. DirtAddsHP General DIY Discussions 14 04-23-2009 03:51 PM
putting a window into an existing concrete wall morningstar2525 Remodeling 5 04-13-2009 12:46 AM
putting tile in bathtub wall lineman8 Kitchen & Bath Remodeling 2 12-27-2008 04:55 PM
