Old 10-26-2009, 09:34 AM   #1
How long can I wait to stain new deck
We recently had our deck rebuilt with pressure treated pine and has been done for nearly 4 weeks. It looks great and I want to get it stained but it has been raining every few days, just enough to get everything wet. I'm planning on using an oil based semi-solid stain. We're getting into cooler weather and less light so it might be very hard to find the time, or temperature, to get it stained before Spring. Is this going to be OK or is there something I should do to protect it before then?
ruleof72 is offline   Reply With Quote
Old 10-26-2009, 10:04 AM   #2
sdsester's Avatar
Some brands of stains are formulated to be applied over newly treated wood but you might have to hit it with another coat in the Spring to get the color you want. Some recommend letting treated wood age for a few months before staining. If you are not sure what to do, an inexpensive, penetrating, oil-based deck sealer would get you through the winter I should think and certainly will not hurt anything. Avoid those with vegetable oils that can sit on the surface. If you use a wax based product like Thompson's you will have to wait 8-12 months before staining.
Obviously the deck needs to be dry before you apply a stain and you will want to do it when there are clear skies predicted for 24-48 hours after with an oil-based product. The semi-solid resins will not cure under a certain temp and can be ruined if frozen so check the manufacturer recommendations for the product you choose to see if you can pull it off still this season wherever you live.
sdsester is offline   Reply With Quote
Old 10-26-2009, 10:26 AM   #3
Can I used a good water based sealant then apply the stain in the Spring? I'm asking this because the temperature/dryness of the deck might be a real challenge to get right now and I understand that water based sealers can be applied on a slightly damp surface.
Old 10-26-2009, 01:03 PM   #4
sdsester's Avatar
I would not because it is likely not to penetrate at all because the treatment was probably an oil or solvent based process. The water based product may just leave you with a slimy slippery mess.
Old 10-29-2009, 01:59 AM   #5
You should be fine just to leave it until the spring. The chemicals used to Treat the wood take time to dissipate anyways, so it's generally recommended to leave the deck unstained for 6 months to a year before doing anything.
idbeolderifiwas is offline   Reply With Quote
Old 10-29-2009, 05:58 PM   #6
Matthewt1970's Avatar
I cuncur. Wait till spring.
Old 04-05-2010, 01:44 PM   #7
Ok, It's Spring and it has finally stopped raining. We had an unusually cold and wet Winter which pretty much prevented staining but I'm finally scheduled to have the deck stained in the next month or so, depending on weather.
My question is now relating to a number of vertical cracks/splits that I have noticed on most of the support posts as well as the posts for the railing. Some of them seem pretty severe to me (up to 1/2 wide, running top to bottom). Should I be concerned? Has waiting to stain had a detrimental effect on the deck or should I be concerned about it?
Old 04-05-2010, 04:51 PM   #8
I think post caps are a good idea.
Jim F is offline   Reply With Quote
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck stain question Cossack Painting 5 07-08-2009 09:42 PM
How long should I wait to prime siding after pressure washing? bluefitness Painting 8 02-12-2009 11:37 PM
